It's Not Just Lucas Starters
HealeyRick
I've been having some hot starting issues with the Healey, culminating with a failure of the Bendix drive engaging at last week's British Car Show in Boston and me having to roll the car downhill and bump start to leave the show field. Then I started hearing some noises coming from the bellhousing on the drive home. When I took out the starter and disassembled it, I found this mess in what was basically a new starter. Luckily, no damage to my aluminum flywheel. The mini starter I used has its own solenoid which I wired in conjunction with the Healey solenoid. After researching it a little further, it looks like when wired with two solenoids the mini-starter can act like a generator unless a diode is added in the system, causing the solenoid not to fully release the starter when the starter button is released. I suspect that's what happened here. So I ordered an older-style starter without the attached solenoid. Wired it up to the Healey solenoid and all seems right with the world again.
Wausau 911
Member
Why wouldn't you have keep the new starter and ditched the OEM solenoid. The new starter probably had a reduction gear. Put on on my BJ7 last year and she starts much better. trying to keep everything OEM?
HealeyRick
HealeyRick
My motor's a Ford V-8 and I bought the mini-starter as I was not sure I'd have room for a full size starter when I did the motor swap. The Ford style mini starters require a second solenoid and that's the way I wired it. There may have been another alternative, but I'll be the first to admit I'm an electrical dunce. Since I needed to replace the mini starter and realized there was plenty of room for a full sized one, i bought one of those at about 1/2 the price of the mini starter.
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
M TR2/3/3A Moss Lucas elektrik alternator install? Triumph 5
A TR4/4A Lucas parts Triumph 7
