    Do you enjoy BCF? Is our forum a useful resource? Do you want to ensure we can stay online?
    Please consider supporting us by **Upgrading**
    [Silver & above members qualify for a BCF email address... Click for Details
TR6 Installing AC in a TR6 ???
TMike
Has anyone installed a modern AC (e.g. Vintage Air) in a TR6? I am restoring a '72 TR6 and would like to add AC. Vintage Air offers a universal unit that includes heat, air, and defrost. This is especially appealing since I need to replace blower motor and heater core in the current configuration.
Thanks!
Marvin Gruber
Mike
I did one a few years ago. It works well. A friend of mine did the installation. I ended up selling the car that summer. Haven't done another TR6 lately but when I do I plan to add that as well. I have several heaters if you need the motor and core. PM me if interested.
Marv
TR3TR6
Marv, was there any issues fitting the unit under the dash? When you ordered the unit, did you tell them what you were putting it into? I put one in my mustang and it fit and worked real well. I also would be interested in putting one in my TR6. Any advise?
JerryVV
I'd like to do AC on my Surrey Top TR4A but I am struggleing with how to drive the compressor as well as how to mount it and space for the compressor.
trrdster2000
All, I have a complete system out of a TR6 and it is a task to get one out. How they put the hoses in the panels and the top hat cover on the inter deck was really interesting, and they also used a smaller glove box, which was plastic, a much better one than the fiber board. Anyone know if someone sells them by themselves?
I won't be using this on my car so if I can help anyone with a part or two, just let me know.
Wayne
JerryVV
That's good information for a TR6 and a TR4 and 4A as far as the interior modifications needed. If I ever figure out how to drive the Compressor on the 4 cly engine Maybe I can do a similar write up. Don't hold your breath!
Darrell_Walker
It seems like about the only place would be on the left side of the engine. I would have to be forward (or low) enough to clear the distributor, but otherwise there may be enough room there. If you could add a second pulley on the front of the existing crank pulley (probably want an electric fan for this, too), then you could drive it that way.
Another alternative for driving it would be to see if you can get the Moss serpentine drive parts from the supercharger kit, that might give you some options. Or do it in conjunction with a supercharger installation :smile:.
JerryVV
Darrell, My thoughts are to mount the compressor as low as possible where the current Alternator / Generator is mounted and get one of the small alternators mounted above the compressor all on the right side. I'd use a double pulley Compressor and drive the small alternator from the second pulley groove. I've already converted to the thin belt pulley set-up. I'm getting a complete engine from a friend to use in order to mock up the set-up. I have photos of an installation done in England placing the alternator on the left side but in order do this the distributor was replaced by a crank fire system. This was done in part to give them enough room on the left side to mount the alternator low and far enough forward to be driven by a double pulley on the crank. I'll send you the photos if you'd like to see them.
JVV
Darrell_Walker
That could work. The compressor should be shorter than the generator, so it won't be so close to the exhaust manifold. Before I installed the supercharger, I had a very compact Nippondenso alternator (from a forklift, I think). It was quite small, but still more amps than the original generator (40 or 50 amps, if I recall).
TR3TR6
That British AC unit looked good to me. The only problem I could see is getting my legs in under the dash with that unit installed. I just barely clear the dash right now. The seats are already all the way back. These six's don't have the leg room that the three's have.
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
W TR6 installing heater hoses '74 tr6 Triumph 1
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
SpannerMan TR6 TR6 seat - installing new diaphragm Triumph 3
tr6web TR6 Installing new lower crash pads - TR6 Triumph 6
N TR6 Installing Flex Coupling for steering TR6 Triumph 5
B TR6 Installing a new dash in TR6 Triumph 38
Slider748 TR6 Re-installing TR6 transmission Triumph 14
PeterK TR6 Installing a TR6 M/C, servo setup in a TR4A Triumph 5
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
