Inside BJ8 seats
JeffR
I know this is a previous topic but can anyone tell me what the insides of original BJ8 front seats (foams) look like?
I wonder if mine are original:
Bottom: Large flat foam with a white fluff open weave batting covering the top. Under the large top flat piece is several smaller pieces glued to conform to the shape of the metal seat pan.
I'm thinking this was not original.
Seat Back:
1/2 inch thick foam strips glued around the perimeter of the seat back, leaving the center area basically open. This is then covered with the large seat shaped molded foam
with the under side in a waffle pattern (holes). This, in effect made the perimeter somewhat built-up and the center
area depressed and softer.
I'm thinking this may be original.
Sorry for the length...but I want to re-create the seats as original and the replacement kit for the back has just one layer of foam with no waffles and no provision for much of a depression in the middle.
Keoke
Nope not original Jeff. Original seat foams to best of my knowledge are available from British Car Specialists in Stockton CA.---Fwiw---Keoke
John Loftus
The original foams had waffle pattern molded into the bottoms and perhaps the seat backs too. I've heard the most accurate foams are being made by/for Heritage Trim. The ones from Moss (6 years ago anyway) were generic and required lots of modifications to fit my BJ7 seats. The ones BCS gets may be different than the Moss ones. Anyway, call around and let us know what you find out.
Cheers,
John
Keoke
Yes John, BCS's foams are not like Moss's and they are correct.--Keoke
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
T TR2/3/3A rings inside bevel Triumph 2
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
Chuck9482912 Letters Cast Inside Engine Block Austin Healey 0
luke44 TR2/3/3A TR3 inside the tires track dimension Triumph 5
tr6nitjulius Oil flow view inside operating engine Other Cars 4
D What's inside the gas tank?? Spridgets 13
C Inside Door Handle Austin Healey 5
J Flaking Paint Inside Differential Austin Healey 6
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
FlyingCat Spitfire Inside door handle Triumph 2
Got_All_4 TR6 Should I paint the inside of the block? Triumph 17
L 100 ID plate inside cockpit Austin Healey 10
G TR4/4A Inside Windscreen Capping Triumph 6
T Frame: Inside Treatment? Austin Healey 8
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 11
DornTRoriginal TR2/3/3A Water Inside the Engine Triumph 4
RickB MGB Rain water getting inside behind dash MG 17
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
M BT7 Inside Threshold Plates Austin Healey 1
B Replacement of Small Black Wire inside Distributor Austin Healey 15
Jim_Gruber Painting inside a BE Boot Spridgets 8
Simmo MGB Have you ever tried removing the spring clip on the Keylock from inside the door MG 0
J Outside door handle opens but not inside Austin Healey 2
BoyRacer thermal barrier on inside of firewall Austin Healey 6
D Inside the frame rails Austin Healey 14
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
K Rough patch inside bore of SU? Triumph 2
P Odometer Finger Prints inside glass Triumph 9
T TR2/3/3A Peak inside the TR3 sill Triumph 8
R fuel tank cap., anything inside displacing volume? Spridgets 3
Patrick67BJ8 Painting inside of block with Glyptal-need advice Austin Healey 10
H inside of wings question Austin Healey 7
arizonamike TR5/TR250 TR250 Inside Rear View Mirror Mount. Triumph 2
wangdango inside of body panels? Austin Healey 10
TraceZ Our sprite is ALIVE - video inside!! Spridgets 7
M Help - inside my distributor Austin Healey 5
H filters inside of BJ air cleaner? Austin Healey 24
AUSMHLY Inside the car Blind Spot Mirror - MacGyvers back! Austin Healey 61
K TR4/4A Exterior of TR4 gas tank...inside OK Triumph 3
I Source for ribbed material for inside bugeye door? Spridgets 5
M Spitfire RARE BL Spitfire parts catalog see inside Triumph 0
T TR2/3/3A TR3 inside door linkage Triumph 8
eschneider help - points / contacts inside wiper motor ?????? Triumph 9
aeronca65t inside pass Spridgets 9
livinginthepast BE bodywork question - inside/fwd hood brace[?] Spridgets 17
