Scotsman
Recently had the steering wheel off and central indicator assembly apart on my 59 TR3. In process I foolishly blew the fuse, flasher unit, and dash bulb. Have replaced all, and the signal lights all work but the direction indicator warning light on dash does not. Horn works. I also converted car from positive ground to negative.
I have tested dash warning light bulb, it works.
Done a continuity test on lead from flasher unit through bulb to ground. Dash bulb and continuity tester bulb illuminate.
Rearranged the 3 wires attached to new flasher unit in all possible combinations and dash light will not illuminate (solid of intermittent).
Got a second flasher unit. (Nappa Thermal Flasher 550). Still no luck.
I have the central terminal on flasher unit going to warning light. If I reverse the leads on the other two terminals indicator lights will no longer work.
What am I am missing (be polite)? Wrong flasher unit? An additional circuit I need to check?
Thanks.
Thanks.
