• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
Indicators stop working
yon_pie_eater
Hello all,
We continue to have an extrordinarily warm winter here, and I take the 100-6 out two or three times a week. The temperature outside is ranging from 10 to around 16 degrees Celsius. The one problem that I'm having is with the indicators.
When I first set off, from the warm garage, all is well, but after a half an hour in the cool air, the indicators will fail, especially if I have the heater and/or the lights on. The routine is always the same - leave the garage and they work fine, ten miles later and they pack in. I don't have the battery on a charger, the lights are nice and bright, it's just the indicators; is there a voltage drop or something as the battery cools down after leaving the garage? Thanks, Andy
Richard Dickinson
Are you talking about the panel lights? Could be the slide switch under the edge of the dash. The switch could be bad and might not be related to temperature.
Johnny
Do you mean all the indicators? (turn signals front and rear) and the brake lights?
It could be something very minor such as a loose connection at the fuse block or voltage regulator box.
Good luck.
Y
yon_pie_eater
Thanks for the replies all,
All the indicators stop working when I drive the car for around for a good while in the cool(but I'm not sure about the brake lights). The panel lights are fine, the battery is only 6 months old, and I take it out every other day. It never needs charging, and the engine cranks over a treat. All the indicators work perfectly again when I first take it out of the warmth of the garage. I'll try the connections and see. (It's forecasted snow tonight here, so we'll be grounded for a couple of weeks - should I order any replacements in this downtime?) Thanks again. Andy.
Keoke
Andy I do not know for sure what you be going on about. However, change the fuses in the fuse block.--Cheers -Keoke
GregW
Platinum
Hi Andy,
It may be your “brake switch overriding relay”. If you have a workshop manual, check pages N15 and N16 for troubleshooting. Maybe try leaving the heat off in the garage and see if the indicators stop working?
warwick-steve Direction indicators not working Austin Healey 29
DerekJ Left side indicators not working. Austin Healey 3
memphis Turn Signal Indicators Austin Healey 20
hymodyne GT6 Side indicators on GT6 MKIII Triumph 2
I Weird indicators on BN1 Austin Healey 4
I Direction indicators/headlamp flasher Spridgets 4
I Dash Indicators both flash, BJ8 MkIII Austin Healey 8
19_again fading turn indicators MG 1
G indicators don't cancel! MG 2
W indicators and brake lights not working Triumph 9
B Direction indicators Austin Healey 3
L 67 BJ8 Turn signal indicators Austin Healey 5
L XJ-S turn indicators Jaguar 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Basil Drop Stop Restoration & Tools 3
D TR4/4A rebound stop clearance issue Triumph 13
edkap2002 TR6 stop light [brake light] swith Triumph 9
B Stop/Tail light wiring Austin Healey 23
O Hesitation on pulling away from stop Jaguar 25
D extra stop/brake light Austin Healey 33
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
warwick-steve Bump stop box query Austin Healey 19
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
HealeyRick Wipers Won't Stop Spridgets 6
T TR4/4A Rear Bump Stop Spacer Triumph 1
M Stop the EPA Racing 7
bugedd Rear axle bump stop Spridgets 7
K TR2/3/3A Clutch Master Cylinder "Stop" Bolt.... Triumph 4
C Bump Stop Box Color??? Austin Healey 4
maxwedge5281 braking circuit through the stop light switch Austin Healey 7
J How to put a stop on the end of a choke cable? Restoration & Tools 2
B LED bulbs as side lights/stop light/flashers Austin Healey 29
tomshobby lower window stop? Spridgets 7
Mickey Richaud MGB Rear Bump Stop - MGB MG 2
PatGalvin The fun just won't stop [engine rebuild questions] Triumph 53
drooartz Off Topic It really needs to stop snowing... MG 19
Tim Tucker TR4/4A TR4 STOP BRACKET for WINDOW REGULATOR Triumph 5
Superwrench Horns won't stop beeping ! Help ! Austin Healey 4
N Running and stop bulbs??? Spridgets 4
J POR-15 where to stop??? Spridgets 30
T She runs! She won't stop running! Triumph 2
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
doates Now how do I make it stop? Triumph 12
M trans leaking, any additive to stop it Austin Healey 13
Trevor Jessie Emergency Stop Spridgets 8
G Racing idle at stop lights MG 3
tr6nitjulius One Stop! In Old out New! Triumph 3
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
DNK And he didn't even stop! Spotted 18
