A nice weekend in Southwestern Virginia is quickly being over shadowed by my ignorance of my ignition system.
I am not getting spark. I have gone through the ignition trouble shooting section in my Bugeye manual and hit a problem on the CB (+ side for a + ground car - correct?) terminal of the coil. I have power on the switch side, but when I check the distributor side with points open, I have nothing.
The manual suggests a bad coil. OK, I have tried three different coils, same result.
I have also tried different points and different condensors. - No help there.
There are no apparent breaks in the low tension wire inside the distributor and the ground wire on the plate is also intact, although old.
What am I missing besides my sanity?
