I'd forgotten...
Nunyas
just how much noise gets trapped inside the car with the hard top on it. I put my SnugTop back on my car this past weekend, and at the time I was more concerned with whether or not it'll amplify the exhaust resonance. I'd completely forgotten how it completely changes the characteristics of the car. Maybe it's just wishful thinking, but I could swear by the seat of my pants that the extra 20 - 50lbs added to the car makes it feel sluggish. However, that doesn't bother me nearly as much as the fact that the valve noise is amplified by about 200% with that thing on the car. It really makes me want to add sound deadening to the whole car, completely rebuild the head, or hurry up and get a new soft top.
It's my daily driver... so, am I bad for not enjoying my car when it wears its hard hat?
I've given this some thought... what I intend to do here is add some sound deadening to the hardtop in the form of a headliner.
Just turn up the stereo!
'64 MGB... What's this "stereo" you referr to?!?
Same stereo my '66 MGB doesn't have.
/ubbthreads/images/graemlins/grin.gif
Truth to tell, I've switched it over to negative earth for just that reason. There will be a "modern" radio in it.
You can have the one I pulled out of my '65 if I can find it in the attic. Radio schmadio! /ubbthreads/images/graemlins/wink.gif
I've driven quite a bit with factory hardtops and didn't notice much of a difference.....with the windows up it's quiter than the softop. I actually really like the B's with hardtops, kinda cocooned.
As of next week, I'll have a factory hardtop for every one of my MGB's!....& only need a couple for all my Midgets to have one (plus need a MkII Midget to go under the MkII hardtop I have!).
Me too!...Course I've got alot less MGB's.
see.... i'm rockin' the "SnugTop" hard top. It doesn't look nearly as nice on the car as an OEM top does. I like the reduced wind noise and the improved insolation from the cold of the hard top, but my top seems to reduce the amount of exhaust note I hear, and increase the amount of engine noise I hear.
I have a radio, but no speakers in my B. Been putting off installing my 1993 Alpine CD player until I recarpet the interior.... been putting off the recarpet until I get the carpet and some sound deadening mats.....
eh... I guess I just like the open feel with the top off. Oh well, can't wait til next year /ubbthreads/images/graemlins/smirk.gif
[ QUOTE ]
[/ QUOTE ]
Completely normal for a hard top.
Bet sound deading material all over inside including the fire wall and a real interior in the hard top would work wonders for the winter.
Wonder if there is an aftermarket blower that would work for the heater to really move some warm air?
The stock heater and blower fan should cook you. I only leave mine on full blast when it's really cold and the top is down. I don't care how cold it is, my feet sweat with the heat on and the top up.
Yup! That thing (in a B, anyway) will make toast of ya in the winter. Western PA gets as cold as -10F, sometimes colder, but we'd still need to "dial it back" after a short while. Very good units.
As I remember Bugeye units are not that good.
[/ QUOTE ]
[/ QUOTE ]
hmmmmmmm... Apparently, mine needs work then. Mine gets hot enough, but it doesn't really "cook" me. It doesn't even get too warm until 20 to 30 minutes after the start of the drive. Or maybe I should swap to a 180Deg thermostat? I've a 160 in there ATM. Or that coolant flushing that I've been meaning to do is in need...
Your heater core is probably clogged up. It's a bear of a job to remove and repair it. You can try flushing and reverse flushing the heating circuit. But if it's that bad then you may want to watch for leaks.
Well, now mine is all shiny-new inside and out! And yes indeed it is a task to pull one.
yeah... not really looking forward to doing it...
