    Do you enjoy BCF? Is our forum a useful resource? Do you want to ensure we can stay online?
    Please consider supporting us by **Upgrading**
i made a stupid mistake. best course of action?
Dan76spit
hi guys,
oh boy did i f-up. while adjusting my valves today my feeler gauge set fell apart and the very small nut that held it together fell off and rolled down the where the push rods come up. it fell into the middle opening where valve 4 and 5 are. i can not see it so i assume it fell down further than i can see. its a very small nut. on a good note the small washer did not fall anywhere but on the head. i found that just sitting there looking at me and laughing. i am going to try to find a small magnetic pick up tool tomorrow and see if i can try to get anything that way.
just wondering what should be my best course of action here. i had all the valve adjusted and was just running through them again to make sure they were all ok as it was the first time i had adjusted valves.
thanks for any advice you guys have.
JImEgan
Try the magnetic tool first. If you get nothing, I think you can loosen the intake and exhaust rocker screws on 4 and 5 to be able to remove pushrods to check in cavities in tappets where the pushrods seat, otherwise you may have to remove the shaft.
poolboy
If you think it's in the oil pan and want to get it out, get a powerful magnet and run it along the bottom of the pan, ending up near the drain plug hole.
Drain and strain the oil. If it's not there, keep fishing.
Are you sure it's not in one of the tappet cups ?
TR3driver
Great Pumpkin - R.I.P
In case it's not obvious, DONT START THE ENGINE.
IMO, odds are good that it's laying in a tappet. Personally, I'd go ahead and pull the rocker shaft, and pushrods, then try fishing through the hole with a magnetic pickup. If you snag something that moves, but seems heavier than just a nut, don't pull it up until you stick something else down the hole to keep the tappet from coming out of its bore.
PS, pulling the tappet up is also a hazard when removing the pushrods, as they tend to cling by suction. Sometimes they'll let go if you spin the pushrod with your fingers. If you do pull a tappet out of its bore, things get interesting :smile:
Dan76spit
no im not sure if its in the tappet cups. i do not see it in there i'm hoping if i can find a small enough pick up tool i can poke it down in there and see. i do have a magnetic drain plug in the oil pan. so i will try with the pick up tool and if i get nothing i will move toward a magnet on the drain pan.
i still cant believe i did this. i feel like crap over this its just starting to get warmer here and was going to go out for a drive this weekend.
JImEgan
I thought "interesting" was one of the reasons we bought LBC's?
poolboy
I fear I'll do something like that every time I R & R the Rocker Assembly.
A washer did slip out of my fingers once but landed within reach.
Dan76spit
ill tell ya i've already had an 'interesting' winter with what i've found in my spit, most caused by the po, i don't need any more, especially one that i caused! :hammer:
thanks so far...
TR3driver
hondo402000
well just hope the nut is not stainless steel which is non magnetic
I wouldnt pull anything at first and see if you can snag it with the mag on the stick, otherwise if you start pulling pushrods and hit the nut you could knock it further down the engine, and if it doenst come out with the oil you might have to pull the head or the oil pan
get a really bright light too
good luck
PeterK
Last year I purchased a borescope inspection camera. It has a small 9mm tip on a flexible 3 foot cable, 3.5" lcd display screen. Great for looking inside walls, behind things, inside plug holes, etc. This one also has a SD slot for recording images or video.
But maybe best of all it has a magnetic tip and hook for retrieving stuff like this.
I used an online coupon and paid around $150 from JCWhitney as they had the best price at the time. HF also sells similar with less features for less $.
It's a cool tool indeed. https://www.jcwhitney.com/wireless-inspection-camera/p2024005.jcwx?filterid=j1
Mine is the $199 one that has recording capability.
Wow, Peter! You could even use it as a periscope to push up thru the pile of snow at the front door, to see if it's spring yet! :jester:
Brosky
I can't tell you the things that I've dropped into the "wrong" places when I was turning wrenches for a living as well as long after that.
I usually look at a job now and remember what can go wrong and fill that area with a shop towel or even an old bed sheet (if pulling carbs or working on the intake) just to catch things that will end up way down inside the suspension.
My wife never throws any sheets or towels away, as I have a use for them in the garage.
I think it's one of Newton's Unwritten Laws: "A dropped bit will seek the smallest, most awkward opening available."
...and a corollary: "Any part/tool dropped onto a floor will seek the very center underneath an immoblized vehicle."
CJD
Try your best to get it out, but I do not personally think a little nut is going to destroy the motor. It can't really hurt the rotating assembly (crank, rods and pistons). It won't hurt the tappets, and won't fit between the tappets and cam. It will eventually drop into the pan and get stuck there, as it won't fit through the screen and into the pump.
The only thing I could imagine it hurting is the chain and sprocket...but that would be a long shot to say the least. There is no direct, and few indirect , route for it to get to the front of the motor, and even if it did, I am sure a hardened chain and sprocket would win out over a cheap Chinese unhardened nut.
I have seen much worse debris live in motors for years and not cause damage, only to be found laying intact in the sludge when the pan is removed. If it was my car, I would go as far as disassembling the valve train to find it...but would stop at more dissassembly than that.
I know this will not be the popular opinion...but it comes from years of my screwing up with things worse than this!
John
:lol:
You're likely correct, John. But I'd use "due dillegence" and attempt to fish it out. And NOT remove the pushrods doin' it.
As for F.O.D. in sump sludge, it seems EVERY Alfa engine I've rebuilt has had at least one chain tensioner wedge bedded in th' muck.
TR3driver
Yeah, most times it doesn't hurt. But it can. One place it could cause problems is if it gets wedged between a pushrod and the side of the tappet. The pushrod wobbles back and forth as the engine runs, so the nut keeps working against the side of the pushrod until it weakens it enough to bend. Makes a mess.
Another possibility is getting caught between a rod cap and the crank cheek. Haven't had that one happen, though.
Dunno if it's true of 1500s or not, but on the TRactor motor, it's not unusual to have the pickup screen break and allow FOD into the pump. I had a con rod lock tab break off once and wind up locking the pump. Fortunately I noticed the increased noise before anything bad happened.
IMO a good oil won't leave enough sludge in the sump to capture things. If it leaves sludge in the sump, it is also leaving it in the rocker shaft, where it will eventually interfere with oil to the valve train. The sludge seems to be mostly broken-down oil additives anyway, which can't be good either IMO.
Dan76spit
well i used a bright light and a small magnetic pick up tool and i do not see it by the push rods or tappets. i drained the oil after sweeping a power full magnet along the underside of the pan to try to draw it to the magnetic drain plug. found nothing in the drained oil so i swept around with the magnetic pick up tool in the oil pan through the drain hole to see if i could get anything but to no avail. i think tomorrow i am going to put the oil back in mainly through the area where it fell in and then drain it again trying to flush it out.
after that i'm not sure what im going to do... i dont really want to remove the pushrods or the head. i dont want to drop the pan either. i'll keep you guys posted tomorrow after i work on it a bit.
thanks for all the suggestions so far.
C TR6 Work Continues. Proggress being made Triumph 6
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 10
D Made a sheet metal break. Restoration & Tools 5
JPSmit Made me chuckle. Spridgets 13
drooartz MGB Made a decision, my MGB is going... MG 102
tr6nitjulius TR6 TR6 made another list! Triumph 5
M I made some embroidered Austin-Healey Hats if interested Austin Healey 4
AngliaGT Miata - ALMOST Made it Home Other Cars 7
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
RAC68 Home Made Healey Exhaust Headers from a BOX Austin Healey 15
Boink Made it into the AHCA club calendar... Spridgets 5
wangdango Home-made ducting for BJ8 radiator? Austin Healey 11
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
Pythias Made the decision to sell. Spridgets 6
M TR2/3/3A What is my radiator made of? Brass? Triumph 6
doc50 TR2/3/3A So I Made My Own Triumph 5
JPSmit Daughter made a video Spridgets 18
S This internet article/post made me laugh... Austin Healey 5
J Made a lot of sawdust today, brought back a lot of memories Restoration & Tools 6
Jim_Gruber Actually made some progress on Bugsy II Today Spridgets 4
Boink Last Midget Made Spridgets 10
60TR3A Had a Portrait Made of My Car Austin Healey 9
T TR2/3/3A We made it -TR3 first trip Triumph 20
oxford Look what I made Dad! Austin Healey 3
B MGB well made sebring valance MG 3
Boggsy64 MGB Made it 2200miles and 22 quarts of oil later! MG 7
JPSmit Land Rover Defender - and Home made special Spotted 1
DanLewis Taking a chance on a Chinese-made aluminum radiator for my Bugeye Spridgets 74
sjuengst Spitfire Handmade toy Spitfire made in the Congo. Triumph 2
hilsideser Spitfire Spitfire also made this list... Triumph 0
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
sd80mac7204 Think I made a mistake Triumph 4
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
C Made to be raced! Austin Healey 11
JPSmit Home made axle puller Restoration & Tools 5
G Midget Cobra? Who made this? Spridgets 19
M_Pied_Lourd Banjo Made Me Do It........ Triumph 11
Banjo If someone made ma a good offer... Triumph 45
rlich8 Today, my day was made! Triumph 27
S This made me smile....... Spotted 6
K seats made for triumph replacement good $ Triumph 12
John_Mc It's made of WHAT?! Triumph 13
M No progress being made Triumph 20
RickB Well my Midget made it home... Need Help! Spridgets 80
drooartz A comment from a friend made me smile. Spridgets 13
hondo402000 TR6 TR6 fan shroud, home made Triumph 7
T Doc made me do it.... MG 28
