I know this is a strange question but......
terriphill
OK, motor's in and we start to crank it...battery's dead. So we charge it. It is a VERY small battery sold by local parts store (500 amps) After a charge it cranks the motor a few times and begins to die again. With the rebuild on the motor...we need more power but we can't find a battery to fit. I took a tape measure to the parts store and all the batteries with enough amps (750 or more...) are 6.5 in. the space in my midget is 6.25 in between the lip of the hood and the heater box. What am I missing? DO I need something special? where do you get them and am I gonna have to shell out another $200 to get it? or is 500amps all I'm gonna get?
jcatnite
Mine is an Autocraft Silver. 51R-1 I think that jar size is about as big as we can put in our little cars. I only got 435 cca but that was enough to get mine started after the rebuild. Might need to give it a little better charge or take the battery to the parts store and let them test it for you. What you have should be enough to fire these engines even when they are tight.
JC
regularman
I would just hook up some jumper cables to a second battery until you get the motor started and run for a while. The motor is probably tight. I have had to use 3 batteries before to get a new rebuilt motor started. All connected in parellel of course. You cna use 24v but not for long, really hard on the starter.
regularman
Oh, and another thing you could do is unplug the heater hose that runs from the copper line to the heater from the heater end and remove the other hose from the heater control valve and hook the hose from the copper line straight to the valve and then unscrew and remove the heater and then you can put a big battery in there and use it for a while.
T
terriphill
Thanks Kim,
I will probably try the jumper cable trick. THe biggest problem is I still am so bad at timing these cars. I set the timing and then have to fiddle, crank, fiiddle, crank, adjust, crank, and fiddle. By the time I get it to fire, I've juiced the battery. Then I have to wait a few hours with it on the charger and start over.
regularman
I know exactly what you mean. I myself will be going through the same thing shortly (I hope) when I attempt to fire mine up. I just left the heater out of mine to set a big battery in there at first. I dont know for sure how far I am off on my timing yet. Half the time with a new motor I have the timing 180 out and it backfires like crazy, hehe.
T
terriphill
Dontcha just love those flames shooting out of the carb? Speaking of timing. Manual says 10 degrees BTDC. Mine really seems to be closer to TDC. Its not good but it gets better there. Still coughs, burps and backfires though.
neilh
Group 51R battery is available at Costco - $39.99 - its the same as a 92 civic! I bought one a month or so ago and have use it every day while I am testing / rewiring my 79 - including multiple attempts to start it, and it is flawless.
Morris
Terri,
Could you have your dizzy in backwards? It will fit in the drive dog 180 out (guess how I know). That will make it cough spit and backfire like crazy.
jlaird
Yep yep, that's what it does. Easy fix. Turn the peice under the dizzy 180, the one with the gear or............
Put number one plug wire on number 4 etc. etc. Just hook em up backwards as a test.
jlaird
Yep that's the prob with a rebuild. Somehow now mater how careful I am I get the gear 180 out everytime. Now I put it in just right then turn it 180 and all is fine.
JerryB
""""""". What am I missing? DO I need something special""""
Yes....a fully charged battery and a decent starter.
400 cca should be fine on a stock replacement motor.
Assuming the above, then you might have internal clearances inside the motor problems.
Does the motor turn over by hand? Remove the plugs...about 25-30 ft /lbs at the crank pulley bolt.
JerryB
""""""" THe biggest problem is I still am so bad at timing these cars. I set the timing and then have to fiddle, crank, fiiddle, crank, adjust, crank, and fiddle. """"""
Assuming you have the dist in the motor somewhere close(the points just opening and the rotor approaching #1 in the cap and the mark on the front pulley/dampener at about 10* before tdc and the intake valve just closed).
You can use a test light across the points and just as the light goes OUT the dampener mark should be at about 5 to 10* before tdc.
And assuming you have preoiled the motor ??? a squirt of fuel in each carb and it should start immediately. Do NOT sit and crank and crank. If you are using a new cam and lifters you WILL wipe all the moly lube off the lobes with continual cranking and no high oil pressure.
jlaird
Engine should run right off, even with timeing off 10 degrees either way, just point the number one wire at the number one sparkplug, tighten the dizzy snug but not tight and hit it. Actually you can time preaty close by ear.
Morris
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Hmmm, I got to rembember some of this. I thought you could not get the distributor 180 out because of the offset slot on the end of it, but ah, the gear could be off.[/QUOTE]
The dizzy can slide right in inspite of the slight offset. Or at least that is the case with mine.
jlaird
Then you got a bad shaft or something, it was designed to that could not be done.
regularman
Well, hopefully tomorrow I will find out how far off my timing is. Car is still bare metal with everything off of it but I want to see if anything is wrong with all the stuff I have done with the 5 speed conversion.
racingenglishcars
General rule of thumb for rough timing. To make sure you are not 90 out or 180 out or anything else.
After turning the engine, it never rests at TDC or BDC. It always rests sort of half way in between.
Therefore pull the valve cover and distributor cap and;
When valves 2 & 4 are open, the rotor should point between cyliders 3 & 4
When valves 3 & 8 are open, the rotor should point between cyliders 4 & 2
When valves 5 & 7 are open. the rotor should point between cyliders 2 & 1
When valves 6 & 1 are open, the rotor should point between cyliders 1 & 3
jlaird MGB Strange daily question. MG 10
tahoe healey strange OD question. Austin Healey 9
J TR4/4A Strange question that may involve the coil- Triumph 13
jlaird Todays strange question Spridgets 6
John_Mc Strange question Triumph 21
jlaird Strange question Spridgets 6
jlaird Another strange but not dumb question Spridgets 1
Vargus TR2/3/3A Strange dents Triumph 19
nicko Strange Engine Noise Austin Healey 7
C MGB strange?? MG 3
J TR2/3/3A such strange thread on gear shift knob Triumph 12
7 Strange A/C - radio problem Other Cars 7
S TR2/3/3A Strange part Triumph 3
steveg Strange gasket pieces Austin Healey 5
steveg Strange Oil Leak Austin Healey 7
D TR2/3/3A Strange hole! Triumph 5
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
Jim_Gruber Strange noises - Bad U Joint perhaps? Spridgets 10
Michael Oritt Strange debris found in sump Austin Healey 19
F TR2/3/3A Strange Loud Noise Triumph 11
C Strange...can won't start and then magically ressurects Austin Healey 16
bighealeysource Strange problem with throttle staying open Austin Healey 6
D TR2/3/3A Strange Transmission Issue Triumph 9
Rhodyspit75 Strange windshield washers Spridgets 0
andrea Very strange austin healey 3.9 Austin Healey 5
M Strange Healey Tach Austin Healey 9
Rut Strange occurance! Spridgets 19
aeronca65t Big Healey-strange wheels Austin Healey 12
bighealeysource Okay, here's one with a strange noise from the engine Austin Healey 7
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
B Strange rear light Other British Cars 6
KVH Strange Sound Like Compressed Air Escaping Triumph 14
Bremer TR2/3/3A TR3A: Strange brake bleeding behaviour Triumph 4
B SU Carbs have strange vacuum fitting Triumph 17
Kleykamp TR2/3/3A Strange TR3 side curtains ??? Triumph 13
HAN8L1965 Strange event ? Spridgets 6
T strange litter Triumph 5
aeronca65t Strange and interesting MGs MG 3
PAUL161 Strange 5 Speed Conversion - Will it Work? MG 41
W Strange occurence Spridgets 5
P Strange clunking noise Triumph 20
bugedd Strange trans noise Spridgets 7
Musicman Strange Clicky/Tappy Sound Triumph 6
SilentUnicorn Strange things British Motorbikes 4
Bremer Strange, but interesting... factory blunders? Triumph 8
M another strange bugeye on ebay Spridgets 12
JAV strange noise Austin Healey 4
J Strange electric problem. Jaguar 11
