how to remove crankshaft key?
MTribe
Anyone have any ideas about how to get the key out of the slot on the crankshaft? It's the one under the timing chain gear.
I can't get that bugger out of there, and need to take it out to get a couple more shims in there to line up the timing gears. Thanks for any ideas!
TR4
If your talking about the Woodruff key shaped like a half moon, on my TR4, it is only resting in the slot on the crankshaft. Try a solvent or WD40 to loosen it up. If it is rusted in there, you might need to bump it with a drift.
MTribe
MTribe
Hmm... it looks more rectangular to me. It's 1.75" long. I've tried tapping it on the end to loosen it with a drift, grabbed it with vice grips and hammered the vice grips to pull it out, but the vice grips just slide off and the key is getting pretty beat up.
I suppose I could just cut a notch in the shims, but at this point the key is damaged enough I think I'll have to get it out anyway.
Argh!
martx-5
Use a good sharp pair of dykes. Lay it flat on the crank around the key. Squeeze tight to get a good bite, then lift the handles up. This usually works for me. The trick is SHARP dykes, coupled with the leverage advantage of using the length of the handles prying up.
Brosky
Soak it with penetrating oil overnight and tap a flat punch down and into to it to drive the half moon shape out of the crankshaft machined slot.
It looks rectangular on top, but the bottom is a half moon shape.
TR3driver
Great Pumpkin - R.I.P
I've had good luck using a cold chisel as a pry bar. Place the cutting edge against the end of the key, give it a whack with a BFH, then pry the key up.
But if the above tricks don't work out, use a Dremel and an abrasive cutoff blade to cut the key in half.
MTribe
MTribe
Hey thanks for all the ideas... although I should have had a V8.
After scoring up the key, and putting some new marks in the crankshaft filing them out, I realized I could simply cut two slits in the shim to make a little flap through which the key could slide while installing the shims. Then it flaps back down once the shim is past the key. OK, so I wasn't using my brain...
2wrench How to remove pistons and crankshaft Triumph 22
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 2
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 16
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
toysrrus TR2/3/3A What tool to remove Dust Cap? Triumph 12
AngliaGT TR6 How Do I Remove the Vacuum Hose Base? Triumph 1
drooartz Tools needed to remove front & rear suspension Spridgets 24
Z TR6 remove transmission Triumph 3
MG Lily Best way to safely remove minor surface rust? Restoration & Tools 5
bighealeysource Best way to remove very fine scratches in chrome windshield frame Restoration & Tools 2
