G
I am blowing oil out of my rear crank seal, I think. When I push the car really hard and finally come to a stop and shut the engine down, I am getting a white smoke coming from beneath my engine from the area of the transmission. I posted this question before and I have all the components for a new seal, ring gear (missing a tooth), clutch and TO bearing. My question is, when the engine is pushed hard, does crank pressure build? I don't think I have enough vacuum on my crank. The only thing that is pulling on the valve cover is the 3 ZS carbs, and this goes through an oil separator. On normal driving, this oily smoke doesn't appear as apparent. I am very tempted to use that extra little nossle (now blocked off) on my intake, the other operating my brake booster. How could I hook up that vacuum outlet, maybe through a PCV valve, and still be able to use the carbs vacuums. Make sense? GoodParts markets a PCV valve that I think works in conjunction with the trips setup, frankly haven't bothered to call him. Any ideas out there.
Bill
Bill
