Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed]
twas_brillig
We got our 3000 Mk II BJ7 on the road last summer for the first time in decades, but the bonnet will not stay latched. Drive down the road and it'll bounce itself loose, such that the two secondary 'hooks' on each side of the bonnet will have to hold it in place.
Any advice as to what to adjust and how to adjust to keep it shut?
Thanks,
Doug
GregW
Platinum
Hi Doug,
The first thing I'd check is if the locking mechanism is greased and sliding to it's fully locked position without binding.
AUSMHLY
Hello Doug,
I will assume your bonnet is lined up and seats properly.
1) Make sure the bonnet catch slider moves easily.
2) The bonnet latch spring must have a constant pull on the bonnet latch slider. The slider will be pulled to the right. (Photo 4)
3) The guide plate is centered. It will be centered over the bonnet latch hole when it is in the open position. (Photo 3)
4) Adjusting the base plate to the left or right will align the striker pin over the guide plate and align the bonnet. (Photo 1)
5) Adjusting the striker pin length will determine how flush the bonnet will be with the shroud and how far down the pin will go into the latch. That adjustment is done by turning the striker clock or counter clock wise. The nut on the top of the threaded striker pin will set it in place. (Photo 2)
If the tip of the striker is at the correct length, seating down in the latch slider, then the spring is not pulling on the slider with enough pressure to lock it in place.
If the springs pressure is not letting the slider move, then the striker pin head is not below the latch enough.
When you push down on the bonnet, you should hear the latch make a click.
I would start with those items.
Maybe the head on the pin does not have a good lip for the latch to grab.
Maybe the base plate is not secure and moving.
Maybe the spring is not strong enough.
Maybe I'm too sexy for my shirt.
Let us know if any of these items help.
Cheers,
Roger
AUSMHLY
GregW said:
Hi Doug,
Yeah, what Greg says.
Off the path here, just wanted to say congradulations on the number of posts you have today, on this particular post. 4444. Right on Johnny on the spot. OMG, I see I joined this fun place 11 days after you. What a slacker I am, I have only 1119 posts. :bow:
Cheers Greg,
Roger
GregW
Platinum
I can see why. In that first photo it looks like you stabbed your hand with the hood pin. What's with all the blood? :lol:
P.S. Cudos to you for getting the shot with your good hand. And making a more thorough answer.
T
twas_brillig
Thanks for the advice and photos and level of detail - hopefully this weekend as it's supposed to be sunny and warm and Healey is outside while the Bug-Eye got its engine pulled last night to get a 5 speed.
And the guy across the street was out in his shorts and t-shirt, shovelling snow off his lawn...
Do you guys in California get to have as much fun as we do?
Thanks again,
Doug
If all else fails, and it's at all like my 100-6, try grabbing the bonnet latch hole piece and pulling it slightly upward from the rear. Mine has a tendancy to drift downward at an angle over time. :smile:
Larry
Keoke
twas_brillig said:
The guy across the street was out in his shorts and t-shirt, shovelling snow off his lawn...
More: we have all girl crews in short shorts and T shirts that come around and shovel the snow off our lawns.- :banana:
Thanks again,
Doug
Tell em I've got snow right now!!!!
Larry
Keoke
:savewave:
GIRLS,-- :wh------------------------Keoke- :laugh:
Larry
AUSMHLY
Larry
If you're referring to the latch slider, then I'd take the time to take the entire unit out of the car. Make sure the metal slider is straight, not bent. Grease the slider and make sure the two spacers are the same size.
I try to figure out where the problem is, how it came to be and fix it.
Sometimes the part needs to be replaced if it can not be fixed.
Good luck,
Roger
Hi, Roger - I've got a little bit of an offset between the slider and the post that comes down. It's on the list of things to do, but right now
I've got the entire interior torn out, putting a new carpet in. You're right, fix it before it is unrepairable! :iagree:
Larry
pablogum
Hi all, I reviewed all posts re adjusting the hood latch assembly and easily adjusted the latch plate relative to the pin. However, I need to adjust pin longer, but cannot see how. There is a lock nut I see, but I cannot get to it.
So how do I lengthen the pin? Do I need to remove the pin assembly?
Thanks, Paul
BJ8
AUSMHLY
Hello Paul,
Yes, you need to remove the baseplate first. The striker pin is bolted to that. Once removed you'll see a slot in the top of the striker pin for adjustment with a flathead screwdriver. Loosen the nut, adjust the pin length, tighten the nut. Reassemble the base plate and see if you have the correct length.
Three adjustments can be made at the striker pin location.
1. the striker pin length
2. the base plate position
3. the hood latch support bracket.
Good luck.
C Bonnet Latch/Release Adjustment Austin Healey 3
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
Willie_P TR4/4A Tr4 bonnet latch bracket [highly technical] help! Triumph 6
Rut Front tilt bonnet latch Spridgets 40
S Jammed Bonnet Latch Jaguar 2
J Bonnet latch Austin Healey 3
angelfj1 TR2/3/3A TR3A Bonnet Latch Triumph 6
Rut Bugeye bonnet latch Spridgets 13
memphis Bonnet Latch Austin Healey 4
eschneider xj6 bonnet latch help Jaguar 7
B TR6 TR6 Bonnet Latch Cable/1972 Emission pic Triumph 31
Cain Bonnet Spring/Latch Triumph 4
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
