RAC68
In preparation for taking an initial vacuum profile in preparation for the installation of an oil catch can and PCV, I was surprised to find a vibrating needle with low readings (7” to 14”of Hg) at a 900RPM idle. When preparing to adjust the valves, in concert with recommendations, I found cylinders 2 & 3 with black plugs and a nice brown on all others. Following the valve adjustment and after exchanging black plugs their light brown counterparts, I took the car for an hour’s aggressive ride and then reexamined all plugs. Expecting to find cylinders 2 & 3 turned black, I was surprised to that all plugs were a nice brown. However, the vacuum gauge still displayed a low reading with a vibrating needle.
Now phase 2. Early this morning, after an aggressive run (it is common for me to shift between 4K & 5K RPMs), I ran a compression test. The reading were as follows:
Cylinder 1 2 3 4 5 6
Dry 170 162 165 171 171 172
Wet 210 200 210 183 183 183
As you will note, reading are within 10% of a selected Base reading,
BASE % Difference from Base
Dry 171 -0.58% -5.26% -3.51% 0.00% 0.00% 0.58%
Wet 200 5.00% 0.00% 5.00% -8.50% -8.50% -8.50%
However, Cylinders 1,2,3 jump substantially to a high pressure where Cylinders 4,5,6 move moderately higher.
Based upon the above information, what is your diagnosis?
By the way, the engine is running strong and without any obvious problems.
All the best,
Ray (64BJ8P1)
All the best,
Ray (64BJ8P1)
