Hi BR,
The Holman cam is rated at 275 degrees duration (valve open time in crankshaft degrees) & installed slightly advanced. The lobe center angle is 108 degrees, overlap is 57 degrees, lift is .434, intake closes at 64 degrees abdc. This cam is very similar to the Piper BP220, the DWR8, & the Kent AH2.
For reference, the later BJ8 cam is 252 degrees duration & installed slightly advanced. Overlap is 37 degrees, lift is .368, intake closes at 56 degrees abdc.
The point of intake closing probably has the greatest affect on low rpm power. Compared to the BJ8, which closes the intake at 56 degrees after bottom center, the Holman cam closes at 64 degrees after bottom center & so will build less cylinder pressure (torque) for a given rpm. The increased overlap of the Holman cam at tdc, 57 degrees vs 37 degrees for the BJ8 cam will give a rougher idle & less low rpm torque.
In general terms, the Holman would probably be considered a fast street cam.
My personal feeling is that unless you plan on turning the engine over 5000 rpm a lot, the BJ8 cam would be more suitable. If you don't mind a fast, rough idle, & turning the engine faster to obtain a given amount of torque, then go for the more radical cam. It will give a bit more power over 4500 rpm.
When any cam is reground to give more timing & lift, the cams base diameter is reduced which puts more stress on the cam lobes & followers.
Cams ground on new blanks can have the larger original base circle & still give the desired timing. Some times, old cams are built up with weld & then ground to the desired contour. This gives the desired larger base circle & works ok if the welding is good.
When using a higher lift cam, always check clearance between the open exhaust valve & the cylinder deck. If there is too much lift the cylinder block needs to be relieved to give exhaust valve clearance. Depending on the head gasket thickness this sometimes occurs around .430 valve lift & over.
By all means, have a machine shop check ALL of your followers for a hardness of RC 55 or greater. I probably don't need to say that all followers should be reground or new.
