Holey gas tank
classiccarguy
The more I get into my 54 TF the more I find. Naturally. I looked down into the gas tank through the fill hole only to see daylight in the corner. Took off the tank and found that the left corner and side each has large holes and the bottom has small holes and the right bottom is rusted through. I took it to awelding shop, but they think the seams and mounting braket are soldered on and they think the tank might leak elsewhere if they weld on it. A new tank is about $1,100. from Moss and that is out of possibility oweing to other items needing repairs. Anybody ever repaired a tank with the bottom in this bad a shape. I thught of Fiberglassing, but they say Ethanol will eat it up. I can buy Ethanol free gas (at a premium price) here in town or use boat gas additive to keep Ethanol from melting the fiberglass. Anyway, your thoughts would be greatly appreciated, as I am a novice with the T series MG. Thanks, Classiccarguy.
George
I would still try to patch. There is some epoxy out there now that is pretty strong. Also meant to tell you, contact this guy there in Shalmar. I met him at Road Atlanta this spring, he may can help you out.
Bert Everhart - (Destin Car Club) 850 218 4465
Marv
Deleted member 8987
I had a friend years ago, retired AF LTCol, who took an old tank in his 1951 Ford Fordor that was rustedtohell, and fibreglassed it. I found him a good one later, gave it to him, but he never put it in as the patched one worked.
No idea....just passing it along.
JPSmit
It strikes me that this is a job you might want to farm out. A quick google shows a number of companies that do this. Here is one, on the left coast I know but... Bike shops might be a lead also
https://www.leakersgastanks.com/
aeronca65t
I'd fit a racing style fuel cell. Added safety, much cheaper and lots of sizes available.
Check Here
PAUL161
Nial, He's talking about a 54-TF! No place to hide a fuel cell that I know of, on a street version anyway. T series tanks can be coated inside with a very hard product. Mine was done before I got it, so who done it and the name of the product isn't available. The coating in my tank is a light Grey in color and as hard as glass.
Ethanol will eat fiberglass! Ask any long time boater with an inboard fiberglass tank. Stabil developed a Marine version gas additive to counteract the damaging effects of Ethanol on old rubber and fiberglass. Not cheap, but it seems to work. PJ
bobhustead
As noted by Smit, there are repair outfits. Their process apparently works, though I have no direct experience. I recall several of them listed in Hemmings. I don't know the exact geometric shape of your tank, buy a competent weld shop should be able to build a close replica.
Bob
PAUL161
Abington spares has new tanks for TCs, TDs and TFs! $950.00 PJ
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A TR3 gas filler cap Triumph 1
J TR2/3/3A TR3A gas tank repair Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
T TR2/3/3A TR3A Gas Cap Triumph 15
D Gas Pedal Pad Jaguar 7
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
T magnets and gas tanks, and other applications Austin Healey 3
Michael Oritt Gas cap parts now in tank Austin Healey 17
Rhodyspit75 Bonnet gas struts Spridgets 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
K TR2/3/3A Gas tanks...two different types? Triumph 5
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
R TR2/3/3A Installing gas tank Triumph 6
