Hold Down Straps for BN-1 Battery Access Door
TodE
Working on the interior of my 55 BN-1. I can't remember if the battery cover door has the "split rivits" for the hold down straps for the lift the dot snaps, showing on the outside of the door lip, or if they are hidden under vinyl that wraps the door.
I seem to remember a close-up picture of this on Alan Afano's pink and black 100M, but I can'tr find the picture.
Reid, how is it on your 100?
Thank you in advance for all your help!
Tod
bighealeysource
Hey Tod,
Pictures I have seen show the rivets exposed. Per Anderson/Moment they were "black headed rivets".
Regards,
Mike
MikeAH100M
I can send you a scan of the Anderson Moment page showing the Access Door straps and description if you would like. Send me a PM because document is too large by Forum limits to attach.
Mike
T
TodE
Michael,
Thank you for your reply! I did them exposed and I am going to paint them black, unless you tell me otherwise. I am coming to PGH next weekend, to see mom and dad (92 & 95 yrs old!) I am still planning to bring the 100 Lemans up if I get it finished for the vintage race in July. (If I get the interior and a short sorted out. SO CLOSE.) I hope to meet you and the "M".
See you soon! I hope.
Tod
MikeAH100M
The pictures in the Anderson Moment book show the black rivets exposed with the leather hold down strap riveted between the Armacord and the metal door. The description also indicated that there was Armacord on the bottom inside of the door to prevent shorting the battery.
It would be great to see you at the Vintage Grand Prix. I'll be at the British Car show on 7/19 and have Patron Parking spaces on the course for Sunday 7/20. No 100's at the Show last year. I'm in the same boat on my 56 100M. Completed the mechanicals. Just have to do the interior and figure out the gremlins from redoing the wiring harness.
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
S TR2/3/3A trim to hold down the furflex Triumph 3
wangdango BJ8 inner battery hold down? Austin Healey 4
K TR2/3/3A TR3 Dist points plate hold down screw size? Triumph 9
I Bugeye hold down brackets not lining up -help Spridgets 13
K TR2/3/3A TR3 Hardtop Hold Down Bolts? Triumph 4
af3683 TR2/3/3A TR3 "J" Bolts for Battery Hold Down Triumph 7
K TR2/3/3A 57 TR3 gas tank hold down strap mistery? Triumph 5
smaceng Rear Brake hold Down Spring Spridgets 3
C Another forward tilt hold down question Spridgets 5
Tinkerman TR2/3/3A Spare tire hold down system, TR3, post 60000 Triumph 8
cdsmith "Tilt forward bonnet" hold-down question... Spridgets 7
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S TR2/3/3A "Teeth" to hold the paint Triumph 30
K TR2/3/3A Brake caliper hold bolts? Triumph 1
D MGB Painted rubber bumpers. How long will they hold up? MG 1
Rut TR4/4A 67 TR4a restoration on hold Triumph 25
C TR4/4A Interior hold-downs Triumph 8
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
K TR2/3/3A The "brass wing nuts" rhat hold the instrument panel on...... Triumph 2
Jim_Gruber Brackets to hold top frame on a BE Spridgets 22
I How do I get a hold of Hap? Spridgets 2
C Midget Brakes will not hold pressure Spridgets 6
C Midget Brakes will not hold pressure MG 19
vping Nut will not hold torque. MG 3
S hold metal together? Triumph 17
HAN8L1965 Length of Steel Wheel Tire hold town Spridgets 7
tweety Home made heater valve will it hold...... Spridgets 3
M Rostyle Wheels: Speak Now or Forever Hold Your Pea Spridgets 17
G The tinworm is starting to take a hold Triumph 16
wkilleffer Size of the nuts that hold the carbs on MG 13
Louie Mk 2 Auto transmission speed hold Jaguar 2
Sherlock Purists... Try to hold your noses... Mark 10 Jaguar 2
SHG Buy, Sell, Hold Austin Healey 17
78Z Added gas struts to hold up hood [bonnet] Triumph 3
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
Sopwith_Camel up or down? Jaguar 12
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey fold-down windshields? Austin Healey 21
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
