TR6 High temp paint required for TR6 valve cover?
tdskip
The valve cover gasket was leaknig, and one thnig led to another and now I have a sandblasted valve cover neednig paint.
Do I need a high temp paint for this?
Thanks!
DNK
Have it ceramic coated. It's just money. :laugh:
DNK
Tom, Someone told me if you want Hi Temp but don't like the color choice just paint it with regular and use a Hi Temp clear on top.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Do I need a high temp paint for this?[/QUOTE]
Not if you chrome plate it.
Buy high temp red paint for the engine.
martx-5
swift6 said:
It doesn't need high temp paint. Any paint you want will work fine for it.
Finally an answer that makes sense!!
If your valve cover gets hot enough to blister regular paint, you've got bigger problems then losing some paint on the valve cover!
dklawson
AMEN !!!
19_again
I used a moss paint on an MG and covered that with a high temp enamel only to protect the paint from solvents etc. If you like shine it looks good.
eejay56
My whole engine is painted with regular Rustoleum (except the header, I painted that with Rustoleum BBQ Black) It's held up great so far. If you think about all the rubber and plastic in contact with it that stuff would burn up at temps high enough to cause paint to break down.
Brosky
A nice basic blue/silver combo with subtle applications of RED in the most appropriate locations.
Rather well thought out and tastefully executed, I might add.
healeyboz High temp green paint Spridgets 15
F Engine Paint...powder coating or just high temp? Triumph 7
MikeAH100M High Temp Engine Miss Austin Healey 2
R low/high temp engine running question Spridgets 23
Carlbanan56 MGB High beam problems MG 4
Carlbanan56 MGB High rpm problem MG 27
G High Oil Pressure Austin Healey 2
P TR2/3/3A British High Torque starter Triumph 6
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
D TR2/3/3A Alternator dial runs high Triumph 5
steveg High quality hose clamps Austin Healey 3
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
W Tachometer reads high when engine compartment heats up Austin Healey 3
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
4tecdog Misfire at high revs Austin Healey 21
warwick-steve Steering high spot - midway Austin Healey 17
warwick-steve High compression head identification Austin Healey 16
J TR4/4A High Water marks? Triumph 5
John Turney Another High-Priced "100" Austin Healey 11
D High beam Lamp Spridgets 3
D 69 E Type High Idle Jaguar 9
B TR6 TR6 High Oil Pressure Triumph 20
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
