Hey Geo - Steering Wheel Question
jsneddon
so what paint did you use on your JB Weld-repaired steering wheel?
Geo Hahn
Sorry -- been on the floor of the garage fighting the clutch hydraulics on the TR4.
I started with a primer coat (clear) using a product called 'Bulldog Adhesion Primer' sez 'makes paint stick to plastic'... manufactured by 'Klean-Strip'.
Top coat was gloss black SEM brand 'Flexible Coating' for 'most flexible & rigid plastics'.
Both products came from an auto paints store.
Don Elliott
I tried Krylon Spray Black Paint for Plastic and it did just the same as regular black spray as well as clear coat spray. None of it would level. It was all pimply.
Don Elliott
jsneddon
jsneddon
[ QUOTE ]
Jim,
I saw the following while flipping through the Eastwood catalog:
https://www.eastwoodco.com/jump.jsp?itemID=2569&itemType=PRODUCT
Anyone here used this?
Mike
[/ QUOTE ]
Nope. But I've used the PC7 stuff that they are using to fill the cracks before in a different application. Pretty much the same idea as JBweld. 2 part epoxy that dries nice and plastic-like... can be sanded down after it hardens to get the curves you are looing for without the need to be crazy with accuracy when you slop it on.
So the kit is pretty much the same as what Geo has done and I'm planning to do but more expensive. If you *need* that much JB weld they sell it in cans at Home Depot, etc. I'm thinking a pair of the regular tube will be plenty to fill the cracks in mine.
jsneddon
jsneddon
[ QUOTE ]
Don Elliott
[/ QUOTE ]
Did you use some kind of primer like the one listed above?
Don Elliott
No I didn't. It's all sanded off again ready to try something better. The JB Weld I used to fill the split has worked fine. The split was about 7" long and about 1/8" wide tapering down to a point at each end of the split. It is well hidden on the back of the steering wheel down near the bottom.
Don
kodanja TR2/3/3A Hey Its been a while Triumph 5
JPSmit Hey Tom! Other Cars 15
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
Keoke Hey Use guys Austin Healey 1
Basil Admin Note Hey Joe Reed! Your watch MG 4
Keoke HEY!! Austin Healey 2
Mickey Richaud General MG Hey, Drew! MG 2
Keoke Hey !!! Austin Healey 7
W Hey Drew.... Spridgets 27
Mickey Richaud Hey, Walter! Other Cars 4
Mickey Richaud Hey, Walter! Other Cars 1
Mickey Richaud Hey - J-P! Other Cars 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
Mickey Richaud Hey, Tom [Nutmeg] Other Cars 2
Mickey Richaud HEY, Nial! Other British Cars 6
Mickey Richaud Hey, J-P! Other Cars 7
5 hey new here Other British Cars 6
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
JPSmit MGB-GT Hey Mickey - here's a mod for the GT MG 10
J Hey, Northern California Healeys Austin Healey 0
Sherlock Hey Walter! More IHC trucks for you Other Cars 4
Mickey Richaud Hey, Tom [Nutmeg]! Other Cars 3
JPSmit Hey Billy! Other British Cars 5
Mickey Richaud Hey, J-P Other Cars 11
Mickey Richaud Hey, J-P! Other Cars 10
Cottontop Hey, Healey Rick.... Austin Healey 1
A Reversed battery posts?? Hey Pat, get this! Triumph 35
Morris Hey JP...OT Spridgets 7
JPSmit Hey Doc!!! Other British Cars 3
JPSmit Hey Nial Other British Cars 2
gsalt57tr3 hey all Triumph 10
AngliaGT Hey Doc - Did You See This Cortina? Other British Cars 1
DNK Hey Andy Triumph 9
JPSmit Hey Theron Spridgets 4
DNK Hey Doc Lotus 1
Mickey Richaud Hey, Nutmeg! Other Cars 1
JPSmit Hey Morris Spridgets 3
JPSmit Hey Mickey!!! MG 4
JPSmit Hey Jack - you neeeeed this! Spridgets 5
jdubois Hey, at least she kept failing in style! Triumph 6
Mickey Richaud Hey, Basil - Other Cars 8
DNK Am I a Fool? [Hey, Rhetorical Only!] Triumph 18
G Hey JP Spridgets 1
Mickey Richaud Hey, Doc and Mark II Other Cars 5
JPSmit Hey Doc & Mark Other Cars 16
Mickey Richaud Hey, RANDY! Triumph 1
JPSmit Hey Drew! Spridgets 9
vping Hey an Latest from VPING!! - My '63 MG 2
DNK Hey Lotus 18
G Hey Hap, got $25 ??? Spridgets 16
