Help with 1979 Radiator
Blackjokr
hey guys! Car is at the egnine shop. They can;t complete it without a new radiator and slave cylinder. I got the cylinder covered, but any idea on the radiator? Moss Motors tells me it has to be rebuilt. I found a place "radiator.com: that has a 1975 on back to a 1967. Anyone know if the 1975 will work in the 1979? Lord help me, this car is costing me a fortune!
best,
BJ
GB1
I believe the earlier ones are smaller, and have different mountings. But I am not sure, it has been a long while since I have had a 1500.
Patrick
B
Blackjokr
ok thanks, maybe someone can be sure.
Bugeye58
BJ, according to my information, the '75 used a radiator that was only for that year. Anything from '76 up will work.
Have you looked into having your existing rad re-cored? it's usually cheaper, and of better quality than the current crop of repros.
Jeff
aeronca65t
Yeah, I had my old rad re-cored after I saw the poor quality of the replacement part. I had mine done by a radiator shop in Dover, New Jersey (near the Moss Motors store). It was about $200.
jlaird
Joker, have you talked to Tony?????????
Didn't TBird Tony have to fix his recently?
GB1
That wasn't the place on rte 46 by the ski shop, down from the quiet man was it?
He screwed up two BE radiators on me years ago.
Patrick
B
Blackjokr
Moss is by Dover?? I am in Freehold, NJ....!
B
Blackjokr
Problem is I need it ASAP! Only place I found one was VB. The car is at the restoration shop, but he sent it out to the engine shop. They found the slave cylinder needed replacement as well as the radiator. Now he;s tellign me the drive chain cover look slike it was Bondo-ed and I need one of those ASAP as well. Tony, can you get that to me ASAP?? I'll contatc him.
jlaird
He even has a phone.
tony barnhill
Great Pumpkin - R.I.P
t'll take about 2-3 days for me to get one pressure tested, cleaned, repaired as necessary (longer to recore).
JPSmit
Blackjokr said:
Problem is I need it ASAP! Only place I found one was VB. ...... Now he's telling me the drive chain cover look slike it was Bondo-ed and I need one of those ASAP as well. Tony, can you get that to me ASAP?? I'll contatc him.
1. Last year during the VB sale I ordered a 1500 (76) rad and they told me they had lost the supplier and didn't know when they would get it back. I don't know if you have actually called VB but just because it is in the catalogue don't assume they actually carry it. The only current source I am aware of for 1500 rads is MGOC spares in Britain
https://www.mgocspares.com/acatalog/MGOC_Spares_RADIATORS___HOSES_162.html
2. Re: timing chain cover - it's supposed to be bondoed - the thread where I learned this is here
https://britishcarforum.com/bcforum/ubbth...true#Post192831
Good luck
jlaird
Haha, that's funny, bondo is orginial equipment.
G
I just went through looking at radiators for my 76 Midget. The fan clutch came loose from the water pump and hit the back of the radiator. Moss doesn't stock radiators for 1500 Midgets. VB has them but there isn't anyone at VB who you can talk to to see where the radiator was made. It costs around $150.00 and I am guessing that it is made in Taiwan or China. I bought a used one from a MG used parts dealer (he said the radiator was in great condition) for $100.00 but when I got it there was corrosion where the tanks are soldered to the radiator core. I sent it back. I finally had a local radiator shop replace my core with a new more efficient USA made core. It cost me $250.00 but the radiator is now better than new. Hope this info helps.
jlaird
I'm telling ya talk to Tony and get it underway if it is a rush.
Spend the bucks to overnite after he has his guys work their magic.
sparkydave
When I had to replace the radiator on mine, the replacement wasn't in the VB catalog. A local shop was able to recore the old one for $100. I just told him it was from a '77 Midget and he didn't bat an eye. If you do, make sure they are aware the brackets aren't symmetric. I had to have the guy turn the bottom one around because the bolts were offset the wrong way.
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
P 2 midget problems 1979 help! Spridgets 2
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
