Help taking apart the generator please.
ichthos
Can someone tell me how to remove the armature from the front plate? I have the rest of the generator apart and just need this so that I can blast and powder coat the case. Thanks,
Kevin
I
ichthos
Yep, that is probably what will happen. Here is a pic.
nomad
Why bother?? I'd use chemical stripper on it and leave it aluminum. Same with the brush plate.
Kurt.
I
ichthos
I am sending my generator in for an upgrade rebuild. This will eventually be taken apart for new bearings, but I am just taking it apart to blast and powdercoat before I send it in so I can save some money. If this piece was normally left aluminum, I will leave it that way. So, was this piece normally just left unpainted?
Brinkerhoff
You need a small two or three arm gear puller to pull the alum. cover off with the bearing. The arms go in the end vent openings and grab the bearing housing so the large alum. plate doesn't flex which will break it. The bearings are cheap and will wear out or oval out the housing if the fan belt is run too tight. Any gen rebuild shop will have the right type of puller. Or Sears, Harbor Freight.
Kevin
nomad
I've seen them unpainted and painted. I believe rebuilts are painted but don't recall on the original's or different models. I believe the original BE's were green. Some one with a Horlers will probably be able to give you good info if you are going for concours. As was mentioned the front bearing plate is fragile and I've only had one gen front bearing fail that I recall. That was a learning experience and after that I always run the belt very loose. It dosen't take much to drive the gen and I've never noticed any undue wear on the pulleys.
Kurt.
I
ichthos
Thanks. After reading your replies, I think I will leave the plate aluminum and let the rebuild guy deal with pulling it apart.
Kevin
G TR2/3/3A Quick Help - taking the cover off a TR3 tranny Triumph 3
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
