• Hi Guest! Being a Paid Subscriber is NOT required to participate at BCF. However, if you enjoy BCF and find our forum a useful resource...
    Please consider supporting us by **Upgrading**
Help! Rover P3500S gearbox lubricant????
eschneider
Working on a Rover 4-speed manual gearbox from a P3500S. (NOT the later LT77)
manual is calling for 20W50, but I've read that the spec has been changed to 75W90..... and /or ATF..... I've seen recommendations for Castrol SMX-S, but that isn't available in the US.
I have no hair left to pull.
Has anyone here had any experience with this? I really would prefer to run Redline Gear lube in this thing, but I don't want to risk screwing up an already dicey gearbox.....
MGZT260
AT fluid is generally not used as a direct replacement for manual gearbox lube in any application. The lubricity and other specs are different between transmission types. AT fluid is essentially hydraulic fluid and in some applications is actually spec'd for power steering and other hydraulic uses. A manual transmission is a gearcase more in line with a differential, although with extra moving (sliding shift mechanisms and synchronizers)within. 20w-50 is a motor oil by design and as such does give up certain properties better handles by labeled heavier gear lubes. This does not mean they actually are thicker, just how they perform.
Keep in mind that UK oil specs and even Japanese oil specs are sometimes based on oils that are not available here - case in point from experience - Kubota, a well-known manufacturer, has consistently called for a certain weight gear lube in transmissions and front axles which, if subbed by a heavy gearbox oil is too heavy, instead their US spec is a 10w hydraulic oil. It took them years to rewrite teh manuals to even just add the proper oil as an alternate spec, even though that's what they leave the factory with. I think the original specs were written for whale oil.
Back to your application. You could use the 20w-50 motor oil as listed but since some evidence suggests alternatives then a proper transmission lube is in order. Do not use Redline regular gear lube, but instead their MTL/MT-90 transmission gear lube. There are differences, as I've said, between duty requirements of an oil involving helical cut gears, synchronizers, and shifting rails as opposed to more simple spiral cut hypoid diff with or without limited slip.
rovernut
<span style="font-size: 20pt"> </span> <span style="font-weight: bold"> </span> <span style="color: #3333FF"> </span> Sorry for not getting on here sooner.........Yes use Redline MTL.....MT-90 is for consistanly higher temps.........20W50 is the lowest you should use but could be enhanced with MolySlip Gearbox treatment.....I've used this before with good results but now with the REdline....this is the way to go...........Drain your old fluid first of course
Good Luck
LarryK
You can also go to www.castrolusa.com and enter year and model of your vehicle and Castrol will answer you on what lubrication is needed in any part of your vehicle. And it will be the latest fluids they have.
jp928
The 4 speed P6 box definitely used engine oil, like 20w50 without issues. I must have done several 100k miles in my 3 cars, always with a very light oil. I doubt they would last on 75w90 heavy type oils. The B version was an uprated internally over the 4 cyl version, with an oil pump. Or get a R380 5 speed box, a prop shaft out of an auto and go for it. A little work needed for the rear box mount, but not hard.
jp
M Help with Rover Parts ID Rover / Land Rover 5
EMGEBE aussie rover v8, .....help!!!.... PRICES???? Rover / Land Rover 2
T Need Help with Rover 1.3 Multiport British Motor Corp 3
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Vauxhall 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
J Wanted Help Wanted -SE WI Other British Classifieds 0
J Help Wanted - SE WI Racing 0
Darwin Spitfire Motor mounting help Triumph 1
Dnickels Spitfire Speedo help Triumph 4
RGK TR5/TR250 SU carb ID help Triumph 6
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
AngliaGT Help Me Identify These Parts Jaguar 6
jlaird MGB V6 carb help MG 14
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
T Bug Eye Heater Switch Help Spridgets 2
G General Tech Help TR-6 Triumph 24
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
R Rust in Block? Help needed! Austin Healey 6
D PDF attachment help FORUM Navigation Questions 1
M General MG OEM Radio wiring help MG 4
J MGB Need help identifying these parts MG 6
G 1960 3000 BN7 Top Help Austin Healey 0
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
B MGB-GT Need help with MGB GT rattle MG 0
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
JPSmit Plywood - woodn't you like to help Restoration & Tools 8
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
S TR6 TR6 Vacuum Issue... some help please... Triumph 8
Bayless Login problem need help FORUM Navigation Questions 7
B TR4/4A Help indentifying these Triumph 5
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
6 Master Cylinder Rebuild Help Please Spridgets 3
