Help Needed on Master Cylinder Fluif
Motopsyche
Greetings all,
While replacing the starter on my '60 TR3A, I had ocassion to disconnect the clutch slave cylinder as it was mounted incorrectly on its bracket. In the process, I introduced air into the system, including the clutch master cylinder (I hate it when the reservoir bottoms out before refilling it during bleeding). My question is how to best bleed the air out of the master cylinder without removing it from the car. Or, am I forced to bench bleed it? After bleeding the slave cylinder mercilessly, the system still has air in it, likely in the master cylinder.
Guidance on best practices for in-car or bench bleeding is much appreciated.
Bill
Indianapolis
TR3driver
Great Pumpkin - R.I.P
Something doesn't seem right to me. If the MC would build enough pressure to bleed the slave cylinder, then it doesn't need to be bled. The process of bleeding the slave should flush any air in the MC out through the system & bleed valve.
FWIW Bill, I bleed mine by simply pumping up the clutch as far as I can, holding the pedal down for 10 or 20 seconds, then releasing the pedal. 2 or 3 repetitions of that has always worked out enough air to make the clutch usable, and then the last tiny bit works out as I drive. If the MC is so airlocked that you can't pump up the clutch, then loosening the outlet fitting and pushing the plunger in by hand will usually get it out.
But based on your description, I suspect some problem like perhaps a weak return spring on the slave and too much freeplay; or possibly a broken return spring inside the MC.
B Help needed on E-Tpe master cylinder rebuild Jaguar 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
E GT6 Help electrical guru needed Triumph 4
R Rust in Block? Help needed! Austin Healey 6
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
J BJ8 Turn signal help needed. Austin Healey 6
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A help needed! fuel problem Triumph 25
M 1974 Jensen INterceptor electrical help needed Other British Cars 8
F General MG Help needed with su dual carburetor identification MG 4
S Wedge TR8 Starter wiring help needed Triumph 18
TomMull Air compressor help needed Restoration & Tools 2
T TR2/3/3A TR3 choke cable connection help needed Triumph 21
Lukens TR2/3/3A help needed Triumph 6
A Fuel Gauge - Help Needed Austin Healey 18
Jim_Gruber Help Needed, getting those 1/4 Eliptics out of the spring mounting box Spridgets 24
E Singer wood frame help needed. Other British Cars 3
JPSmit General Tech Girling Brake help needed Triumph 4
JPSmit Spitfire Girling Brake Help needed [I hope] Triumph 9
A BJ7 - Help Needed Austin Healey 3
Lbp TR2/3/3A Painting Help Needed for Restored Steering Wheel Triumph 5
J Any SP250 owners with Austin Healey [big] rearends e-brake help needed Other British Cars 4
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B Help Needed with Upholstry Problem! Austin Healey 19
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Tinkerman TR2/3/3A Air Deflector Installation Help Needed Triumph 19
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
A Serious help needed !!!! BJ7 Installing a new soft top Austin Healey 9
Tinkerman TR2/3/3A Parts help needed 1960 tr3 a Triumph 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
Tinkerman TR 3 Picture HELP Needed Triumph 5
S Help needed... Sunbeam (Rootes) 7
S Lower Wishbone Fulcrum Help Needed!! Austin Healey 26
S 3000 BT7 Steering Wheel Restoration help needed Austin Healey 3
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
C Mallory dual point recurve help needed Austin Healey 6
Tinkerman Speciality Paint Help Needed Triumph 4
TR4A_IRS Help needed with high idle Triumph 13
Kleykamp TR2/3/3A TR3 Generator mounting issues help needed Triumph 4
Wirewheels Remote purchase help needed! Triumph 8
S Spitfire Spitfire front suspension help needed Triumph 9
R TR 3 Conv. top help needed Triumph 10
M Help Needed. Alternator Question Spridgets 14
rcufley A little ignition help needed Triumph 123
6 Rear brake help needed Austin Healey 10
