Help, BMW 218ti odometer light
jlaird
Shucks, I have the light from the dealer but see no way to get to the dash lights. Tried to remove the covers etc under the dash but even with them out no access. Must be an easy way to do this but I admit I am stumped.
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
I have a set of dealer TIS (TIS = repair manuals on CD).
What series and model#? The series starts with an E (i.e. E21, E30, E46). You said 218it, did you mean 318i?
I'd be happy to send you the PDF instructions.
jlaird
jlaird
Oh shucks, 318ti
don't know about series??
Platinum
3-series Jack /ubbthreads/images/graemlins/grin.gif
The whole instrument panel comes out, IIRC. It has a printed circuit "film" to power all instruments and lights...once you see it you may not like it! /ubbthreads/images/graemlins/jester.gif Nothin' like Miss Agatha.
Scott_Hower
[ QUOTE ]
Oh shucks, 318ti
[/ QUOTE ]
Gimme the last 7 digits of the VIN. As Doc said, you might not like what you find /ubbthreads/images/graemlins/lol.gif
jlaird
jlaird
AU39804
Heck I thought the AU ment it was an Austin in discuise. Sigh.
GB1
Sounds like a carb part # to me. /ubbthreads/images/graemlins/jester.gif
Scott_Hower
[ QUOTE ]
AU39804
[/ QUOTE ]
Here's the parts book diagram for the cluster; looks like it comes out in one piece - as Doc said. Need to find the other CD for removal instructions. Stay tuned.
Scott_Hower
Cluster removal instructions and bulb removal instructions. Hope you have the "special tool" /ubbthreads/images/graemlins/devilgrin.gif When in doubt, improvise.
<font color="red"> EDIT: Jack, I just noticed the instructions say to recode the cluster when reinstalling. Only a dealer can do this, as the mileage is stored there and replicated to the LCM/light control module. You might want to proceed with caution. </font>
Page 1:
Page 2
Page 3
Platinum
I have been able to remove the bulb sockets with just fingers.
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
Thats a relief. Any idea if this is going to cause any issues with coding? I just realized the E36 cluster is electronic. Dont want to cause an expensive trip to the dealer /ubbthreads/images/graemlins/blush.gif
jlaird
jlaird
Oh no, first step is removeing stearing wheel, I think she is just going to have to shine a flash light on the odometer when she needs to read it. No way I go through that for a darn bulb on a BMW. Now if it was my Bug that's a different matter. The bulb is the only thing that does not work on the car, fixed all else, just junk stuff.
So there it stays without a light.
Thanks guys, appreciate the help.
Scott_Hower
[ QUOTE ]
[/ QUOTE ]
Wimp /ubbthreads/images/graemlins/devilgrin.gif
It's just a nut /ubbthreads/images/graemlins/angel.gif
I installed a factory rear sunshade/roller blind in my 330i last year to keep the sun offa the littlest one. Had to remove darn near all of the rear upholstery to fit the thing.
https://www.bimmerfest.com/forums/showthread.php?t=45744
Platinum
If the main harness is not energised while the pod is out/disconnected it shouldn't cause and issues... but I'd be with Jack on this: put the bulb in the glovebox! /ubbthreads/images/graemlins/devilgrin.gif
jlaird Require some BMW help Other Cars 13
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
