Heat Shield
Musicman
Hello to all. Well, my heat shield arrived yesterday. Installing it was easy. This weekend I'll see if it makes a difference in starting the 6 when the motor is warm/hot. Hopefully it will make starting the car easier when the motor is warm/hot.
Has anyone out there seen an improvement when it comes to this? All responses are welcome.
Thanks,
Dave
T
Tinster
Hey Dave,
Not sure if it's related but I installed a carb heat
shield and then the distributor blew up, the hydraulics
for my clutch blew up, my car was stolen, then recoved,
the cross shaft taper pin broke and the car spent 7 months
on jack stands being repaired.
I don't currently have the heat shield installed.
Your install will probably work out better than mine.
d
T
Tinster
Yup, tis true.
Clan Fraser of Lovat- we never give up.
Some of us Frasers have been known to lose
our heads because we never give up.
My poor uncle Simon Fraser has a rough go
of it in the Tower. And poor cousin Christopher
got burned at the stake.
A stubborn lot we are~
d /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
Musicman
Musicman
Hello again. Thanks for all the replies. The heat shield definitely makes a big difference in how the car runs. My idle is now much smoother and more stable now. And starting when the motor is warm is also much, much easier.
Dave
malice
Seems to me from what Ive been reading that triumphs in general have a problem with heat lock. I know my car has some metal lines under the hood. I once heat shielded my mustangs starter with a stop sign from down the street though (it is about 1/8 aluminum) and it worked great. Glad its working for you.
T
Tinster
Now, ya just to keep an close eye on your tranny.
After my carb shields, the tranny mounts decayed
to dust, the tranny locked up in 2nd, one rear
wheel stud fell off the car and the front wheel
bearing blew out. The spark plugs fouled out and
the lead wires fried. Two coils burned up and a major
hole developed in the driver's floor pan.
You have to constantly fine tune that carb shield
or you could be in for trouble.
d
V heat shield Triumph Classifieds 7
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
K TR2/3/3A Revington alternator heat shield. Triumph 0
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
tahoe healey Dynamat heat shield Austin Healey 8
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
R TR4/4A Tr4a, alternator heat shield Triumph 9
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
I How do I install Bugeye heat shield? Spridgets 4
Gliderman8 Heat Shield - will it solve my problem.... Triumph 15
I Bugeye heat shield color? Spridgets 11
Dudly Heat shield Triumph 0
19_again Carb heat shield MG 7
bigjones Vapor lock. Heat shield for fuel pump? Spridgets 5
M SU Carb Heat Shield Triumph 6
c5racer Gaskets with the heat shield? Spridgets 0
T Heat shield pictures- anyone have one handy? Triumph 3
J Heat Shield Material / Carpet Dye? Austin Healey 15
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
19_again MGB MGB exhaust heat shield MG 3
Trick6 Tri Stromberg Heat Shield Coming This Spring/Summe Triumph 16
LastDeadLast Heat shield for HS8 carbs Triumph 3
tony barnhill MG Midget Heat Shield Spridgets 30
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
Steve P. '78 Midget carb heat shield? Spridgets 1
T Ratco Cable + Heat shield Triumph 30
6773 heat shield Spridgets 7
mjobrien Cockpit Floor Heat Shield Austin Healey 4
kyreb1862 MGB Heat Shield Color On A 77 MGB MG 1
A SU H1 heat shield Spridgets 5
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
R Exhaust Heat Shield Austin Healey 3
