Spitfire Headlamp poser - 71 Spitfire rebuild
Dono
Hi,
I cannot get the high beams to come on. Good continuity from the main sw, thru the column mounted dimmer on both low & high beams. The red/blue and wh/blue wires have continuity to the lamp plug. I've tested the lamp, and both low & high work fine. They are new head lamps. Summary - low beam works, high does not. Any ideas are welcome.
Thanks, Don L. Missoula, MT
TR3driver
Great Pumpkin - R.I.P
Don, "continuity" frequently includes a resistance too high to pass enough current to light the bulb. I would go back with it hot, and use a test lamp or voltmeter to find out where the voltage is missing.
On my Stag, it was the dimmer switch on the column, but it could be anywhere.
Andrew Mace
I'd also thoroughly check and clean the ground (black wire) connections to the headlamps; that's a somewhat common "failure" point on that era of Spitfire in particular. Check especially the connections from the main harness where it connect to the headlamp subharnesses (usually up in the bonnet or in that general area in the front of the car).
Dono
Hi Randall,
I of course, appreciate all responses, but I believe you correct. Even though the col sw passes a current, it appears failed. In checking, the failed high beam sw acts as a resistor, and only micro-voltage passes.
Thanks for saving the head-banging frustration. Don :smile:
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
6 BJ8 Headlamp Wiring Austin Healey 1
D TR2/3/3A TR3 Headlamp Rings Triumph 8
F T-Series Lucas m133 headlamp? MG 2
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
D Fugly Headlamp Bowl Gasket Austin Healey 7
AUSMHLY Best 7" non sealed headlamp Austin Healey 19
luke44 TR2/3/3A TR3 Headlamp Confusion TS31000 car Triumph 18
Kirk_Fisher TR4/4A TR4 headlamp switch Triumph 3
S Headlamp Relays vs. New Headlamp Wiring Harness Austin Healey 6
AH3000MkIII BJ8 headlamp dip switch bracket Austin Healey 7
GBRandy Wedge TR8 Headlamp lift motor repair Triumph 17
DerekJ 4 Headlamp Healey - Summary Austin Healey 0
I Headlamp alignment Austin Healey 3
W Headlamp rims Spridgets 7
Andrew Mace Lucas headlamp rim 54522186 Other British Cars 4
6 Headlamp/relay Question Austin Healey 6
M TR2/3/3A TR3 Headlamp Rim Triumph 4
I Direction indicators/headlamp flasher Spridgets 4
Moseso Need a headlamp upgrade? Check this out -- Triumph 32
V Headlamp switch question Spridgets 2
69mgbgt Spitfire 1971 Spitfire headlamp switch Triumph 14
T TR2/3/3A TR3 headlamp dimmer switch Triumph 7
JohnnyMead TR2/3/3A TR3A Headlamp Trim Rings Triumph 4
Brosky Masters Headlamp Wiring Harness Triumph 25
C Headlamp buckets Austin Healey 4
Brosky Headlamp Relay Kits Triumph 12
Geo Hahn Adding a Headlamp Relay Triumph 19
T TR4/4A 4A Headlamp Trim rings Triumph 7
B TR6 Another TR-6 headlamp problem Triumph 7
B Correct headlamp rims Austin Healey 8
sultanoswing Headlamp Upgrade - Hellas or Cibies? MG 2
Johnny Headlight, [headlamp], rims Austin Healey 8
S Wedge TR7 headlamp problem Triumph 18
V Elan Headlamp vaccum system Lotus 4
TypeRboy Headlamp vacume valve.. Lotus 6
Gundy Poser pic Spridgets 1
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
