I replaced my needle valve on both front and rear carbs. It had not been leaking before. I adjusted the carb using a ColorTune. I drove the car and smelled gas on the short drive. It was leaking around the connection between the banjo and the car bowl. I ordered new bolt and new banjo with new fiber washers. I replaced it and now it still leaks, just not as bad but still dangerous. Have the threads in the carb just worn out and will not seal? Is there a way to improve the seal on the threads into the fuel bowl? Can I send my carbs off for rebuild and get this corrected. I have not messed with the carbs in about 15 years.
