H button - what should it be connected to?
Cookie
Member
Dear all
I've got a H button on the dash of my 71 Sprite but it doesn't seem to do anything. I've followed the cable that it's connected to and it goes to the top of the heater box under the hood but it must be broken. The heater has got a valve that turns the heater on and off and I am assuming this works fine, it's on at the moment and that suits me but it would be good to turn it off from inside the car when I've got a passanger. Is the H button the control to do this? If not what does it do and how easy would it be for me to mend?
Ooh - so many questions...
Cheers!
Melissa
It controls the air flap that allows(or blocks) air flowing through the heat flaps/demisters.
Cookie
Cookie
Member
I've got an electronic switch on the right of my dash that seems to do this - is this in addition?
The switch turns the fan blower on/off, but the H-knob opens/closes the air passage.
Jim_Gruber
There is also a valve right at the back of the valve cover that opens and shots to allow water/coolant to go into the heater core. You can shot off the valve in the summer to help to keep from toasting your legs.
Cookie
Cookie
Member
Jim, think I've found the valve on the top of the heater, is that the one that screws up and down?
Joe - Are there? I'm off to investigate! I may need more direction though if I can't find them!
Cheers :eek:)
Cookie
Cookie
Member
Ha ha thanks Joe - so there are - and there's one missing in the passenger side - just a gaping hole, so that's why my mom complained so much about the heat, ...and I thought that she was over-reacting! So what are they called then? I'll have to get on the lookout for a replacement one!
Ooh I love my car - so many fun things to find out. So what other secrets is she holding that I don't know about - and I don't mean the worn clutch!
drooartz
As you must know, a lady never reveals all her secrets.
One good thing for you to do is get hold of Moss Europe (I assume by the West Midlands location that you are in the UK) and get one of their catalogs. Even if you don't order anything from them, they're a great view of just about every part on the car.
https://www.moss-europe.co.uk/
I use the Moss US catalog often as much as my shop manuals for views on how a component goes together.
jlaird
Block off that duct hole into the passanger foot well for the summer with a bit of duct tape. Hmmm, that sounds about right, duct tape for the duct hole.
Cookie
Cookie
Member
Well thank you everyone! A pair went on ebay for silly money but it looks as though I've tracked one down - along with everything else I need from a chap in Derbyshire. With luck we'll get some sun so we can enjoy a run into the countryside! Great tip re the moss catalogue for how things should look - will have to get my hands on one.
Cheers! :eek:)
D TR2/3/3A Traffic at or and horn button not working Triumph 2
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
nevets BN6 horn button Austin Healey 17
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
NutmegCT Thanks button - part 2 FORUM Navigation Questions 8
John Turney Thanks button error FORUM Navigation Questions 2
T Handbrake button Austin Healey 0
K Restoring Horn Push Button Austin Healey 12
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
NutmegCT TR2/3/3A SU-H "lift button" Triumph 12
Zitch Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
Martinld123 Push button on top of new H6 carbs float bowl from Moss Austin Healey 3
W TR6 tr6 horn button Triumph 2
W TR6 horn button wiring Triumph 5
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
J WTB: NOS bugeye horn button, and MkII Sprite Hood Emblem Spridgets 1
T TR2/3/3A horn button Triumph 12
R 100-4 starter button Austin Healey 1
Bruce Bowker BN2 center horn button assembly Austin Healey 21
Bruce Bowker BN2 center horn button assembly Austin Healey 6
Zitch Horn Button installation Triumph 4
S WTB: Non-Adjustable Horn Button for a 3000 Austin Healey 6
C Horn button Austin Healey 0
M stainless push button snaps for convt boot Austin Healey 2
H horn button for BN6 "non-adjustable" Austin Healey 4
S TR2/3/3A those metal button trim pieces tr3 Triumph 5
F TR2/3/3A Horn Button TR3 Trafficator; Bad ground? Triumph 4
BillW103 Horn button Spridgets 2
S solenoid without a button Triumph 5
A TR4/4A TR4A e-brake button keeps falling off Triumph 6
5 Longbridge screen washer button dimensions Austin Healey 8
H BJ7 horn button, same as Sprite? Austin Healey 5
K TR2/3/3A Best way to clean TR3 Bakelite horn button? Triumph 8
H source for horn button BJ7 Austin Healey 3
ArcticOne Spring Button Replacement Triumph 8
UmmYeahOk Spitfire GT6/Spitfire E-Brake Button Triumph 7
M Handbrake Button Austin Healey 1
UmmYeahOk Horn Button Restoration Triumph 11
S Tachometer thrust button Austin Healey 1
chicken Spring length for horn button Austin Healey 3
ekamm TR2/3/3A TR3 door cap button Triumph 4
B Looking for 64-67 midget horn button parts MG 0
