GT6 GT6 fuse box replacement
pei
Member
Hi All,
I have two problems to throw into the great knowledge pot:
I have had an intermittent problem with the power wire from the light switch to the middle fuse. I replaced the high low column switch first and then found it was the headlight master switch. I then replaced that but am still having the problem once and a while. I am tired of losing half the electrical in the car when this happens.
Anyway, I want to replace the old three fuse box with a modern fuse box and seperate all the areas into their own fuses.
I have a few questions before I venture into this:
Does anyone know where I would find out what amps the individual items would be fused at when seperated, or would they all be the same as when they are when grouped together?
I was going to get the new fuse box from the wreckers,is there one make/model better than another?
Has anybody done this already?
Second problem:
I have an electric fuel pump, and late last season the car got hard to start. I have to let the pump run much longer to get the car started. Once it starts it runs fine, and starts pretty reliably, but after it sits over night, it is hard to start again.
Any ideas where to start looking, maybe a fuel pressure check?
Thanks for any help.
Joe
DougF
Have you cleaned all of the connections at the fuse block? If you aren't making good contact, it can cause this problem.
These fuse blocks are very simple and very functional. Are you wanting to increase the number of circuits? Why are you looking to change?
P
pei
Member
Hi Doug
I wanted to isolate some of the circuits so when or if I have a problem, three or four things would not go dead as a result of one problem. I have cleaned the fuse box terminals, the wiring system was out of the car and rebuilt back to factory specs, but I did not replace the fuse box trerminal. The previous owner had it running on two out of three fuses. I am going to replace the box because its terminal contacts are showing its 37 years. I thought this might be a good time to eliminate the multiple circuit fusing.
P GT6 GT6 fuse box replacement Triumph 0
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ā€˜72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM ā€“ 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
glemon GT6 GT6 Getting Some Recognition Triumph 8
R For Sale Triumph GT6 3.27 rear Triumph Classifieds 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
Spritey For Sale .. or [TRADE] Early GT6 seats Triumph Classifieds 1
R Wanted Overdrive gearbox for GT6 Triumph Classifieds 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
Steve GT6 Spotted 2
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
R GT6 Early Gt6 Pushrod tubes Triumph 14
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
dklawson GT6 GT6 Clutch Failure - Where to Look First Triumph 16
anarchy99 GT6 Rear window fitment for gt6 Triumph 1
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
TR6BobNF GT6 GT6+ Parts for Sale in Newfoundland, Canada Triumph 0
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
