Grill changes to Vintage race car?
VelodromeRacer
I have seen that some have put a wire grill in place of the stock chrome grill in the Bugeyes to gain more cooling area? Any thoughts on this? I noticed a few weeks ago while testing at the track, my oil and water temps were close in temp, but while it was a hot day, 210 seemed too hot for the water.
Is this allowed for vintage racing?
Anything else I should do?
aeronca65t
Hmmm? I thing it would depend on the club. Up here in the northeast, VRG would not care. And HSR does not seem to be too concerned about this type of stuff. Not sure about SVRA, VSCCA or others.
Really, your car should cool OK with the stock grill. If it doesn't, you may want to look at various colling-system issues.
My car has a ~Stainless Steel Wire Mesh Grill~ , but that was mostly because the stock one was really trashed and I had the wire mesh on hand. My car has the highly efficient 1500 radiator, so it wasn't really needed.
VelodromeRacer
VelodromeRacer
What temps do you see with that car and the MG Rad?
aeronca65t
Actually, only about 160 F in the Summer time. I am using a blanking plate (which, in my case, is just an old thermostat with the guts removed).
I will really need to blank off some of the radiator if I use the car in cooler times. Last week at Watkins Glen I was only seeing about 130-140 F.
Keep in mind that I am running the 1500 engine (but I think this radiator can be adapted to run in the "A" series engine too....actually, I'm planning on running it when I do my 1275 swap in this car).
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
S TR2/3/3A bottom of the grill screws Triumph 3
C refinishing/polishing 100-6 grill parts Austin Healey 2
M Wanted MGB grill 1963 to 1969 MG Classifieds 2
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
Rhodyspit75 Bugeye grill surround piece Spridgets 5
J 3000 [BT7] with 100-6 Grill Austin Healey 2
A Stag Wanted -Hi-Res Image of Stag Grill Emblem Triumph 0
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
S Works Grill Austin Healey 3
Rob Glasgow Question on Grill Mounting Austin Healey 4
Rut TR4/4A TR4a grill refurb Triumph 11
maxwedge5281 gas tank and grill installation Austin Healey 29
M BJ8 grill removal Austin Healey 5
Rut TR4/4A Correct grill? Triumph 6
S TR2/3/3A grill and apron opening Triumph 18
AUSMHLY BJ8 eyebrow over or under grill surround Austin Healey 9
sqbsprite TR6 Any good examples of custom grill inserts? Triumph 1
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
David Townsend TR6 TR6 Grill Badge Decals Triumph 6
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
Tinkerman TR2/3/3A 1960 3A Grill question Triumph 4
Tinkerman TR2/3/3A Prepping the grill for installation for my 1960 TR3A Triumph 1
Tinkerman TR2/3/3A Mounting the Wide Mouth Grill Triumph 5
B BJ8 grill surround Austin Healey 16
B Rally Style Grill Austin Healey 9
D Need Help,What is the correct way to install grill surround on bonnet? Austin Healey 5
HealeyDave 100 Grill - Correct Finish? Austin Healey 3
aeronca65t Robin Hood Grill Other British Cars 4
tinman58 TR5/TR250 TR 250 Grill Triumph 14
C 66 Sprite orignial grill Spridgets 2
Rut Bugeye grill question Spridgets 40
B General MG grill MG 22
6TTR3A TR2/3/3A Late TR2 Grill surround Triumph 12
Jeepster MK 3 chrome grill surround Austin Healey 25
Trevor Jessie Looking for a grill Spridgets 10
I TR6 TR6 grill emplem help please. Triumph 16
B 57 smallmouth grill, chrome trim, and trim clips Triumph 7
Stinger TR4/4A TR4A Correct Grill Mounting Question Triumph 1
wangdango BJ8 grill polishing? Austin Healey 12
K bugeye grill installation Spridgets 12
J Jag with BE grill? Spridgets 0
M 1974 MklIII - inner chrome grill trim Spridgets 2
tmc TR2/3/3A TR3A grill Triumph 7
CJD TR2/3/3A TR3 Grill decisions Triumph 27
D Grill emblem Austin Healey 7
S 100-4 grill Austin Healey 6
Nelson 50th Grill badges Spridgets 2
I BCF grill badges? Spridgets 14
