Girling Brake Calipers - Resleaving with SS
angelfj1
Does anyone know of a company who can insert Stainless Steel sleaves into my Girling brake calipers? This is a 1960 TR3A.
Are you sure that you need this, the only precision part on the Girling caliper is the piston. (unlike other designs) Unless the calipers are badly damaged all you should need is a rebuild kit (new O-rings) and new pistons which ideally would be SS. Just make sure that the o-ring slot is clean.
Yisrael
