Sorry to keep bugging you with this, but I can't seem to make it mesh. If I bolt the bracket to the generator via the single hole first, there's a space between the bracket and the hole on the engine front plate. The spacer I have has two threaded ends a fatter portion that looks like a pulley.I think its VB #2-785 That portion is too wide for the gap. I can't seem to locate any other type of spacer. Can I fill the gap with a bunch of flat washers and use a regular hex bolt or should I use VB #14-899 even though its for a 1098 and I have a 948?
