TR2/3/3A Gear oils for TR3
prb51
Gents, I am using a GL4 90 weight for my gearbox in deference to the yellow metal issue. Should a GL5 be used in the dif?
Geo Hahn
MT90 says it is GL-4 though I do not know if it has stuff in it that is bad for copper alloys.
75W90 NS says GL5 and that it contains "improved copper corrosion protection which prolongs the life of synchronizers". This is the flavor that Moss sells.
MT90: https://www.redlineoil.com/products_gearlubricants.asp?pvID=74&prodID=57&subcatID=18
75W90 NS: https://www.redlineoil.com/products_gearlubricants.asp?pvID=109&prodID=57&subcatID=18
Yes, my understanding is that there is no brass or bronze in the diff.
prb51
prb51
GL4 is ok for yellow metals and GL5 is not. The chem compound that allows for the GL5 rating degrades yellow metals. Thanks for the info, I've been running GL4 in both but the redline should be better protection for the dif.
MDCanaday
You can call me nuts but I swear by STP mixed with 90 for the diff. I had a bad bearing in a diff that made noise, too broke from college, I changed the sick old grease and mixed in 40% STP. It was quieter and in fact ran well for the next 17 years!!
MD(mad dog)
TRTEL
I don't know how corrosion prone they would be, but the thrust washers behind the sun and planet gears are some variety of bronze.
prb51
prb51
Trtel, Was unaware of that. I won't use a GL5 in that case. Napa sells GL4 by the gallon and that's what I've been using. Not going to take a chance on a 50 year old rear end (mine or the cars).
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
Joe Reed MGB Dropping out of 3rd gear... MG 2
J Planetary Gear Removal Austin Healey 3
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
