gas tank strainer in Bugeye
xkejoe
getting ready to clean and seal my gas tank and realized there is a strainer in the gas tank. how the devil do you change this thing ?
65_BRG_Sprite
I asked that question couple years back. I can't figure that out either but the lttle bugger was installed somehow. I tried to be as careful as I could when sloshing the sealant.
BlueMax
The tank filter is a non serviceable part; it was installed before the two halves were welded together. I concluded that they felt if the tank was contaminated bad enough to stop the tank filter up that they just replace tank. For the cost of a new tank about $200.00 having peace of mind is worth the cost of a long distance tow bill due to sealant brake down stopping fuel flow. Sealants are a temporarily repair.
HAN8L1965
I did refinish the inside of my tank, I poked around at the strainer to remove as much as possible, now 3 years later i have had my fuel quit flowing on 3 occassions so a new tank is going in in the next couple of months so I have a worry free summer.
paulsherman
If I were you, I would disconnect the gas line from the tank and shove a stiff wire in to unplug or remove what may remain of the strainer or is pluging it.
HAN8L1965
Unfortunately the strainer is part of a housing, at least on my 65, so it is not possible to really get at it, I pu a lot of time in on this thinking I had it licked, unfortunately there is some kind a debris in there that seems to settle in the wrong spot over time, to fix that I undo the fuel line and blow air into the tank, works but I've had enough. I see where VB has tank, straps, and sender as a kit for $180.00, that will work just fine, they charge more for the tank alone.
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
B TR4/4A Gas Tank color? Triumph 4
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
D What's inside the gas tank?? Spridgets 13
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 4
Michael Oritt Gas cap parts now in tank Austin Healey 17
R TR2/3/3A Installing gas tank Triumph 6
FlyingCat Spitfire Gas tank Triumph 2
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Gas tank does not fit! Triumph 4
C MGB Found this spring in my gas tank MG 8
B Stripped Thread in Gas Tank Austin Healey 26
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
S TR4/4A Worm in gas tank? Triumph 7
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
F Throw away BN7 Gas tank Austin Healey 3
F For Sale BN7 gas tank, original. [I think]. Austin Healey Classifieds 0
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
AngliaGT MGB Gas Tank Removal - '67 GT MG 2
69MGC MGC New Gas Tank for my C MG 3
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
K TR2/3/3A Gas tank pipe connector? Triumph 6
S TR2/3/3A gas tank hole body work Triumph 7
maxwedge5281 gas tank and grill installation Austin Healey 29
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
K TR2/3/3A Cleaning a gas tank with muriatic acid.... Triumph 7
C TR2/3/3A Gas tank cover in cockpit area Triumph 3
J TR2/3/3A Gas tank fitting and ferrule Triumph 2
S TR2/3/3A with sugar in the gas tank Triumph 13
Tinkerman TR2/3/3A Another Freeby from the past. For a 1960 TR3A Gas Tank Triumph 4
Gliderman8 General Tech Cleaning sludge/varnish from a gas tank Triumph 6
B TR6 76 TR6 gas separation tank - orientation? Triumph 2
C TR2/3/3A TR2 Gas Tank Triumph 6
R_Lyle TR6 Drain the fuel tank - five year old gas? Triumph 4
davidb AH 3000 aluminum gas tank Austin Healey 5
H gas tank repair 100/6 without killing myself Austin Healey 11
B Gas Tank Sending Unit Orientation Austin Healey 4
R draining old fuel from gas tank 3000 mk II Bj7 Austin Healey 3
BobbyD TR6 TR6 Custom Aluminum Gas Tank ~ 15 Gallons Triumph 1
R Gas Tank Installation Austin Healey 6
Scotsman Gas Tank Rust Removal Triumph 9
vette Gas tank install Austin Healey 7
C Holey gas tank MG 8
