I'm finally ready to start my rebuilt '73 'B but seem to lack one important ingrediant: gas! The fuel pump is new and will pump gas from a container to the carbs but will not suck gas from the tank. Is is possible that the outlet line is somewhat plugged. It does not appear that I can remove the elbow connector from the tank and I am not sure what happens inside the tank from the exterior elbow. I wondered if it is advisable to drive some air back through the elbow to free up any clogs, but I'm not sure if there is a one way valve that I might screw up with too much air. Is there some kind of chemical, perhaps, that can be driven back into the tank to dissolve whatever may be clogging the outlet system. Thanks in advance for whatever input you may be able to supply.
Cheers,
Ceedub
Cheers,
Ceedub
