fuel tank question
HarryL
On my ongoing restoration of the 4a; I
noticed that the fuel tank does Not have
an overflow/air vent. Is this
something I need to address before placing
it back in the car? Was thinking of putting
a brass fitting and running a hose down to the
frame/body.
Harry
RJS
Well, I can tell you I topped up my tank one cold day before storing the car for the winter and discovered gas poured out the filler cap on an exceptionally warm day from expansion. Damaged the paint some but glad the tank didn't rupture from the pressure.
bgbassplyr
ISTR that on a 4A, the cap is vented, no separate vent on tank.
So if turn the car over, run.
TR3driver
Great Pumpkin - R.I.P
The vent on the tank (as found on earlier TRs) can dump liquid fuel on the road in hard turns. So I would suggest verifying that the cap is vented (small hole through the inner plate of the cap) and not filling the tank above the bottom of the fill pipe.
JPSmit Fuel line - gas tank question Restoration & Tools 5
catfood Fuel tank question Austin Healey 1
M Fuel Line to Tank Connection Question [pics] Triumph 2
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
K Fuel tank question MG 17
SCguy TR4/4A Fuel Tank, Fuel line question, TR4 Triumph 7
H Fuel tank screws removal question MG 4
J Inside fuel tank hoses question Jaguar 2
J In-tank Fuel Replacement Question Jaguar 2
G Fuel tank question MG 12
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
BoyRacer Fuel Tank Sending Unit Austin Healey 3
B TR6 Fuel tank replacement Triumph 0
JPSmit Fuel tank sender - how does it work? Spridgets 4
S Large capacity fuel tank Spridgets 1
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
Michael Oritt Fuel tank safety Austin Healey 18
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
R Jensen-Healey Fuel Tank Questions Other British Cars 17
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
F Wanted 1960 Triumph TR3A fuel tank Triumph Classifieds 5
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
SD Bugeye Half capacity of the fuel tank Spridgets 10
B TR2/3/3A Fuel Tank Venting Triumph 8
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
L T-Series TD Fuel Tank MG 2
NutmegCT Fuel tank cleaning/restoration Restoration & Tools 47
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
sim fuel tank sender reading full all the time Spridgets 9
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
J Bugye Fuel Tank Leak Austin Healey 4
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
T TR4/4A Fuel tank venting Triumph 1
L 100/6 BN4 Fuel Tank feed Austin Healey 5
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
T TR2/3/3A Late Fuel Tank in Pre-TS60000 TR3A Triumph 3
R Fuel tank straps Austin Healey 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
L Fuel Tank sender 100/6 Austin Healey 8
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
K TR4/4A Fuel tank options Triumph 4
O TR2/3/3A Fuel tank vent Triumph 1
