Fuel Pump Question
Michael Oritt
If two FACET cube fuel pumps (nominal 2.5 psi) mounted in series were both operating would this double the fuel pressure?
Platinum
Very doubtful. Maybe a slight pressure increase in the line between 'em, but AFAIK it wouldn't be cumulative at the business end. You goin' for 'redundancy'? Put 'em on a DPDT switch: they will push thru/draw thru one-another. The units are relatively bomb proof in my experience, so having two running concurrently seems a bit of overkill.
tr8todd
On one of my previous TR8 race cars, there were two facet pumps hooked side by side. I assume they were for redundancy as I did not build that car. When they were both turned on at the same time, I would get a surge in fuel pressure. It made the car run a little faster when they were both on. I thought that was great until the float bowls flooded and I had a nice engine fire.
ChrisS
I don't know how the pump is constructed but the company literature says that is has pressure relief so I would tend to think that it would build up to the set pressure and thats it. It depends on how the internal relief is constructed. The company website is <a href="https://www.facet-purolator.com/" target="_blank">https://www.facet-purolator.com/</a> , they have contact info on there for technical assistance. It may be a mute point since the pumps should probably be separated and run as redundant pumps in parallel.
JerryB
if you run two pumps in parallel you need to use check valves inline in case of one pump failing. ON PAPER, two pumps in series will double the pressure ...but in reality they wont. Two pumps in parallel ON PAPER will double the availiable volume.
Any electric fuel pump, (or mechanical for that matter) especially with carbs such as Webers (down or side drafts) SU's and any carb that wants to see low pressure, NEEDS a pressure regulator. A decent regulator. Not the regulator that Purolator markets with the adjusable wheel. Were dealing with small increments of a pound in these carburetors and not + - a pound or so. and you need to set that pressure with a reliable gage and not "by ear".
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
M Fuel pump question Austin Healey 3
M_Pied_Lourd TR2/3/3A Fuel pump sediment bowl gasket question Triumph 12
vette New Question About Fuel Pump Austin Healey 12
nevets SU fuel pump question Austin Healey 21
P TR6 Fuel pump question Triumph 10
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
T Question on 1994 XJ12 fuel pump Jaguar 3
6 Fuel pump question Spridgets 14
M Fuel pump torque question Triumph 14
B Series 1 E-Type fuel pump question Jaguar 2
nevets another SU fuel pump question Austin Healey 10
J TR2/3/3A TR3 fuel pump question Triumph 7
JFS Wedge TR8 Fuel Pump Question Triumph 3
richberman Dumb SU fuel pump question? Austin Healey 9
V Solid state fuel pump question Spridgets 2
JPSmit Fuel pump question Spridgets 7
T Quick fuel pump question - mounting angle MG 3
G Fuel pump question Spridgets 2
drooartz Question: power for the fuel pump Spridgets 9
Stinger TR4/4A TR4A Fuel Pump Question Triumph 2
M Fuel pump Micro polish, and shaft seal question Triumph 14
M_Pied_Lourd TR2/3/3A TR3 Mech/Elec Fuel Pump Question Triumph 9
M_Pied_Lourd Old Electric Fuel Pump Question Triumph 15
jvandyke fuel pump relay question Spridgets 5
Bayless SU fuel pump question Jaguar 37
B Question about a fuel pump Triumph 3
sparkydave Electric fuel pump question Spridgets 13
T Electric fuel pump question Triumph 29
Brosky Fuel pump internal valve removal question Triumph 10
S Fuel pump question Spridgets 0
budk1953 Fuel pump question Spridgets 2
MadRiver Tiger fuel pump question Sunbeam (Rootes) 2
RedTR3 TR2/3/3A Rebuilding TR3 Fuel Pump question Triumph 5
Monark192 SU Fuel Pump Install Question MG 4
David_DuBois A different Fuel pump question Austin Healey 3
Michael Oritt Fuel Pump question Austin Healey 5
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
MadRiver Fuel pump question Triumph 11
Sarastro Facet fuel pump question Spridgets 5
DerekJ Bellows Fuel Pump question Austin Healey 2
nevets fuel pump question Austin Healey 1
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
