robert_ellison
It seems that I remember that when turning on the key I heard the sound of the fuel pump priming the lines. I just hooked up my battery but hear no sound, nor when disconnecting the fuel hose from pump to carb I observe no gas in the line.
This car has sit for numerous years. Might this be a problem and, if so, what should I first check/do to verify the pump.
Thank you
Thank you
