Fuel leakage at carby on V12
bella1
When my electric fuel pump is running and the engine isn't, fuel is running out of all 4 carburetors (stromberg cd 2). It apears to be flowing out of two small holes which are located above main air in flow hole. The gasket between the air cleaner housing and the carb' body has holes in it which allow these holes to be seen. I don't think all four needles would be leaking at once?
John S Farrington
In order for this to happen, the needle valves in the float are letting the gas over flow the chamber. I can think of reasons for all four to flood. 1. The fuel pump and/or regulator is deriving too much pressure and causing the valves not to close. 2. All four carbs are flooding due to a lot of debris preventing the valve from closing. It would seem illogical that all four floats would sink or become inneffetive or the four valves would fail at the same time. If your pump is deriving not more than about 3 psi, then you are going to have to look at the floats and needles. What kind of pressure regulation do you have in this car? Is it standard factory or something special? Is the car an E type?
Izual Angel
Wait a sec... do you mean those small rectangular holes directly above the throttle bore?
John S Farrington
I am not rreferring to them. From what you said it sounds like you are flooding gasoline out of side ports that are circular. about the same size as the input to the carbs from the fuel pump. These side ports vent the fuel chamber bowl and will allow gasoline to exhaust when the fuel bowl is flooding. If tdhese are not the ports, then where is gasoline coming from?
John S Farrington
PS,I have just reread your posting and understand now where the gas is going. I have never hear of this one and will have to do research to understand how this is happening. It is a very odd situation.
T SU Fuel Pump Mounting Austin Healey 5
FlyingCat Spitfire Fuel Sender Unit Triumph 2
G Twin HS4 Su's leaking fuel Spridgets 17
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
JPSmit Fuel tank sender - how does it work? Spridgets 4
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
RJS General TR Winter Blend Fuel Triumph 1
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
S Large capacity fuel tank Spridgets 1
D TR2/3/3A rearmost fuel line question Triumph 5
fpstude TR4/4A Fuel Pipes Connector Triumph 4
Healey Nut Fuel Sender Austin Healey 3
Cutrog1 Fuel Pump Ticking Austin Healey 13
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
JPSmit Fuel line - gas tank question Restoration & Tools 5
R TR2/3/3A Fuel Gauge Triumph 19
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
S SU fuel pump servicing Austin Healey 4
steveg TR6 Source for fuel line P-clip Triumph 17
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
BLong63AH BJ7 Hard Fuel Lines Austin Healey 20
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
TRopic6 For Sale TR2/3 Brass Fuel Shutoff Tap [for parts] Triumph Classifieds 0
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Ljohns New Midget/Sprite Fuel Tank Austin Healey Classifieds 1
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
B AH Spares Fast-Flow Fuel Manifold Austin Healey 2
S Fuel gauge calibration procedure Austin Healey 18
M Fuel starvation Austin Healey 7
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
C MGA Fuel gauge question MG 7
vette A Quiet SU Fuel Pump Austin Healey 2
B Under bonnet fuel Austin Healey 15
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
J TR2/3/3A replace brake and fuel lines? Triumph 4
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
