Front suspension rebuild issues
boxfullofyertoys
Hey everyone!
So I was wrapping up the front suspension rebuild today and decided to put the car back on all 4 wheels. When I did, something odd happened. It's hard to describe what it's doing, so I attached a photo below (sorry for the quality, had to use my phone)...
Any idea on what's causing it? It's occurring on both sides. The only causes I can think of are: air in the new unsettled shocks, stiffness from all the new stuff, or the tie rod ends being waaay too far out (I haven't adjusted them yet...)
Thanks in advance for your help!
spritenut
You put the trunnions on backwards.
I have done it myself more than I care to admit.
Easy fix, just undo the trunnion from the shock and the king pin, flip it around 180* and put it back together.
I still giggle when I think about the first time I made that mistake.
The car looked sooo pitiful. :smile:
boxfullofyertoys
boxfullofyertoys
Whoops! Well at least it's an easy fix. I'll have to remember that for next time :smile:
I was so excited to lower it back down and when I saw it not sitting right I immediately thought two things: I'm done for the night and I need a beer!
Hopefully I'll find some time this week to fix it...
Thanks everyone!
60bug
Member
That's funny, my car's up on jack stands as I've been rebuilding the suspension and I was wondering why it seemed like the camber was so far off on the front end after putting it back together, I assumed it would fix itself when I put it back on the ground, now I see I did the same thing, back to the garage!
jlaird
haha, how many times have we seen that here? I have only seen one time in my garage, sheeee.
boxfullofyertoys
boxfullofyertoys
Matt - I was noticing the same camber thing as I was doing mine and figured it would settle out once there was weight on it...it def doesn't. lol
JPSmit
Only once in my garage too, Jack. :cheers:
Jim_Gruber
Well I have the opportunity to do it again in a few days. Have done it once, hope not to do it again.Working at home all week as I have to put some night duty, plus get my regular work done as well. Maybe, I can get spindles repainted plus a few other parts and pieces repainted before it all goes back together. Reight now I try to grab 10 minutes here and there to think about Bugsy and do something little every day. He will eventuially get back together.
HAN8L1965
It helps you get good at doing a suspension tune up. Amazing how we are all so interconnected. I also enjoed putting the bearings in wrong too, nice wobble after all that work.
Must be a SPRIDGET THING!
Mark
jlaird
Wobble? How in the world.
HAN8L1965
Maybe wobble is not the correct word, but you could shake the wheel, I think I had the back bearing in the front and the front in the back. Can't remember, all I know is that it was wrong.
Mark
drooartz MGB Front suspension rebuild is next MG 57
J Front Suspension Rebuild Austin Healey 16
M front suspension rebuild parts list Spridgets 22
M TR2/3/3A TR-3B front suspension rebuild Triumph 0
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
bugedd About to rebuild my front suspension Spridgets 1
R Front Suspension rebuild MG 12
Stinger TR4/4A TR4A Front Suspension Rebuild Triumph 26
jbowlby MGA MGA Front suspension rebuild MG 1
T Front suspension rebuild - TRF kit or piece parts? Triumph 5
T Correct/best order for front suspension rebuild Spridgets 8
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
I Front suspension rebuild help for bugeye Spridgets 6
I TR6 TR6 front suspension rebuild suggestions Triumph 19
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
Jayrz Front Suspension rebuild sequence MG 41
M Front Suspension Rebuild Triumph 21
1 front suspension rebuild, parts? Austin Healey 2
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
John_Mc Front suspension rebuild revisited Triumph 21
John_Mc Front suspension rebuild Triumph 23
John_Mc TR6 Front Suspension Rebuild TR6 Triumph 16
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
jcatnite Front suspension rebuild Spridgets 8
Bill Redd Front Suspension rebuild Triumph 8
77MidgetMkIV front suspension rebuild [spring refit specificall MG 9
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
