Front shocks
macker
OK everyone, I need your help. I filled up the fluid in the front shocks with 80-90 wt oil, didn't need much, but when you push on the front fender the car bounces up and down like crazy. When I drive it, it floats up and down. What is the problem? The springs are new, so please help. Thanks, Jerry
Hello,
sounds like bad shocks. gear oil is not the best thing i would think to use. you may still have some air in the shck itself. You should use the same oil in both sides.
Please check these archives
https://www.britishcarforum.com/ubbthreads/showflat.php?Cat=&Number=43203&page=1&view=collapsed&sb=5&o=&fpart=1#43203
https://www.britishcarforum.com/ubbthreads/showflat.php?Cat=&Board=UBB4&Number=21004&Forum=f4&Words="shock%20oil"&Searchpage=0&Limit=25&Main=20998&Search=true&where=bodysub&Name=&daterange=1&newerval=1000&newertype=w&olderval=&oldertype=&bodyprev=#Post21004
mark /ubbthreads/images/graemlins/driving.gif
Bruce74B
It sound like it is time to give World Wide a call. A couple of people on this forum recommended them to me and I just replaced mine. They are online, but I suggest you look at their site and call them...they are great to deal with and provide a superior product with a guarantee that can't be beat. /ubbthreads/images/graemlins/driving.gif
G
Never use gear lube oil in a shock. There is a special fluid for them or use mineral oil only.
NC Mike
[ QUOTE ]
[/ QUOTE ]
I have to agree with MRBASSMAN that you don't want to use gear oil. Its viscocity is too high. /ubbthreads/images/graemlins/yesnod.gif
In a pinch, I substituted motorcycle fork oil in a '70 Midget I owned years ago.
Correct me if I'm wrong, but I think shock oil is somewhere around a 5-10 weight oil.
Your gear lube is so heavy it may not be able to react to the movement within the shock. I'm not sure how the shock valve would react, if at all, to the heavier oil.
Speaking about valves, maybe that's what needed replacing in your shocks in the first place. But I'm just speculating here.
Mike /ubbthreads/images/graemlins/patriot.gif
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
A Front Shocks Bushing Replacement Austin Healey 2
P TR6 Front shocks Triumph 11
nicko Front shocks Austin Healey 16
M Replacing front shocks, torque setting? Spridgets 2
B Front Shocks Austin Healey 6
RJS TR4/4A Replacement Front Shocks Triumph 4
D front shocks 100 m Austin Healey 12
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
N Hillman Imp front shocks wanted Other British Cars 2
tomshobby front shocks, about time I think. Triumph 6
J Front shocks Austin Healey 5
PAUL161 T-Series TF Front Shocks-[Backwards]? MG 5
J Replacing front shocks. Austin Healey 3
AUSMHLY Front shocks: guaranteed not to leak ? Austin Healey 6
R Bugeye front shocks Spridgets 3
mrsprite front lever shocks for sale Spridgets 2
BOBBYR BJ8 FRONT SHOCKS Austin Healey 10
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S BJ8 Shocks and Front End Austin Healey 15
19_again front shocks filler location MG 4
Shinsen774 Install Front Lever Shocks-What's the secret? MG 3
F TR2/3/3A TR3A front shocks Triumph 2
bluemiata90 TR6 TR-6 front shocks in a TR3?? Triumph 2
B front shocks MG 33
zimmy changing front lever arm shocks Spridgets 4
Morris New Front Shocks! Spridgets 2
kodanja TR6 TR6 FRONT SHOCKS? Triumph 24
D Front Shocks. Spridgets 19
mrv8q TR2/3/3A TR3 Front shocks Triumph 4
jscott TR2/3/3A TR3A front shocks Triumph 1
M Front shocks MG 8
Basil Front shocks installed tonight! Jaguar 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
