Front Coil Seat Dimensions?
I'm considering using a set of rubber Triumph front coil seats as a replacement/alternative for the extortionately expensive ones on a Jensen-Healey. Does anyone have, or know off-hand the dimensions for those used on TR6s?
What I need is a seat that is roughly 4.5 inches across and .25 inch thick on the top, where it cushions the spring, with an opening of approximately 3 inches diameter and a lip that extended down the inside of the spring about an inch deep. the lip is about 1/8 inch thick.
Would a TR6 spring seat fit? I'm wondering about part 57 from this Rimmer Brothers Parts Catalogue.
Thanks.
James
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
S TR2/3/3A Front coil spring recommendation? Triumph 7
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A TR4 front coil springs Triumph 0
KVH TR4/4A Front Coil Spring Spacers Triumph 1
PAUL161 T-Series TF Front Coil Springs MG 1
PAUL161 General MG Front Coil Spring Comparison MGB verses a MG TF MG 4
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
PatGalvin Front Coil Springs Triumph 9
G Choosing the correct front coil spring Spridgets 54
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
S front/rear coil spring diamaters. Triumph 4
PAUL161 Front coil springs MG 1
G Front Coil Springs Removal Spridgets 9
K TR2/3/3A Sticking front brakes? Triumph 9
Z 3000 Front Wheel Bearings Austin Healey 3
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
Z Front Springs Removal Austin Healey 3
Z Front Shocks Austin Healey 19
T TR2/3/3A tr3 front carpet replacement Triumph 5
G For Sale: Triumph TR2, TR3, TR3A Sheet Metal Body Parts – Front Apron (valence) with grille, Bonnet (hood), Doors, Boot (trunk) Deck Lid Triumph Classifieds 3
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
crispy BJ8 Front Suspension Austin Healey 9
B Bent frame rails near BE front end Spridgets 2
K TR2/3/3A Front Hub and Felt Seal Triumph 1
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
F TR2/3/3A front body mounts Triumph 7
8 Wanted BJ7/8 front grill top cowl Austin Healey Classifieds 4
R Wanted WTB TR-3A front bumper brackets [pr] Triumph Classifieds 6
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
R TR6 Front suspension fulcrum pins Triumph 6
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 2
K For Sale Triumph TR3A front bumper and overiders Triumph Classifieds 0
B MGA Front bumper solution!! MG 1
Upland Mark IV front suspension Spridgets 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
steveg Picture needed - front turn light Austin Healey 4
S TR2/3/3A Front Suspension Triumph 6
R TR6 Proper alignment of gearbox front cover plate Triumph 3
J Front Suspension Rebuild Austin Healey 16
I Bug eye front disc brake conversion. Spridgets 5
B MGA Sealant for front plate? MG 1
RAC68 Front Seat-back Angle Austin Healey 14
nichola TR6 Transmission front seal replacement question Triumph 8
