General Tech Flywheel Bolts
DNK
What's the size of the flywheel bolts for the TR 2-6
I've forgotten
Gliderman8
I believe they are 7/16" UNF
DNK
DNK
I have 6 ARP 12 point that have never been torqued.
They have been lubed and finger tightened in the holes.
I can't use them
Offer up for free
First come
karls59tr
Bronze
I'm doing a clutch/flywheel/ TR6trans install on my TR3. Are the bell housing to engine bolts Grade 8 7/16 coarse?.... and are the top two bolts shorter than the rest?
DNK
DNK
On a TR6 I don't know if there are bolts there
charleyf
I do believe that they continued to use the two top bolt holes for studs. I believe that this was to help you guide the tranny into position onto the back of the engine. The studs are 5/16" not 7/16" and yes they are course thread as are most all bolts threaded into the block. Yet most all of the bolts with nuts are fine thread.
Charley
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D TR4/4A flywheel bolts maybe too long Triumph 15
CJD TR2/3/3A Clutch/Flywheel Bolts Triumph 28
J TR2/3/3A Flywheel bolts Triumph 1
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
K TR2/3/3A Torque value for TR3 clutch cover to flywheel bolts....... Triumph 2
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
P Moss Motors Flywheel Bolts Triumph 18
drooartz Clutch to flywheel bolts Spridgets 3
Tinkerman Correct Flywheel Bolts Triumph 6
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
tahoe healey problem removing the flywheel bolts Austin Healey 16
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
Y MGB Flywheel saga continues.... MG 24
Y MGB Flywheel resurface? MG 2
Michael Oritt 100 Flywheel Weight Austin Healey 16
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
WHT Denis Welch CENG635SO Flywheel Austin Healey 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
J BJ8 flywheel take some pounds off Austin Healey 17
roscoe Flywheel orientation question Austin Healey 3
R TR6 Pilot bushing clearance and Fidanza flywheel Triumph 0
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M TR2/3/3A What Flywheel is this? Triumph 3
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R Wanted BJ8 FlyWheel Austin Healey Classifieds 6
M TR2/3/3A Starter and Flywheel Combinations Triumph 2
Rut Crank/flywheel dowels Spridgets 3
JimLaney Flywheel Pitting Spridgets 4
S TR2/3/3A Alloy flywheel Triumph 13
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
drooartz ID a 1275 flywheel Spridgets 2
trotti Flywheel removal Austin Healey 4
drooartz Looking for a 1275 flywheel Spridgets 17
A 1955 100/4 Flywheel Info Austin Healey 4
T Post-War Other Herald flywheel Triumph 3
B Clutch disc - which side goes towards flywheel? Austin Healey 8
abarth69 1275 Flywheel Wanted Spridgets 7
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
K TR6 Flywheel installed without the locating dowels? Triumph 5
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
O TR2/3/3A TR4 Flywheel Triumph 4
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
D Flywheel Ring-gear replacement Spridgets 18
B BJ7 Flywheel Help Austin Healey 11
