Floorboard Sheet Metal Position
vette
Another attempt to get a pic in. You might notice that my floor sheet metal now does not sit on top of the frame any more.
neilert
Re: test
Is there a benefit to the floor sheet metal next to the frame rather than on top? Is it to reduce the water standing on the top of the frame?
vette
vette
Re: test
neilert, yes that is why I did it. I trimmed the floor pan and then made a 90 degree bend down at each perimeter except for the side against the sill which was already bent 90 degrees up. That gave me a very stiff edge to weld on and kept the frame rails exposed to the interior cockpit. the edges bent downward about 1/2 inch, It stiffened the pan considerably, allows the welds to be treated and painted on both sides, keeps the frame rails on top dry and they will be painted with Lizard skin sound and heat insulating product. then dynamat insulation then carpet. there should never be water laying on top of the frame again. The edge that I bent down is bent alittle more than 90 degrees so that it exposes the weld underneath. When I coat and paint the bottom of the car, that bottom portion of the weld will be coated as well. then I will lightly hammer the edge flat against the frame rail and apply alittle more paint again.
GregW
Platinum
Re: test
An elegant solution. But I think you're paranoid, rust NEVER collects on top of the frame.
vette
vette
Re: test
Greg, Are you saying that tongue in cheek or are you serious? Is that picture of your frame in perfect condition or is that a rust blemishe surface? I might be able to accept that if the factory put that sheet metal down very tight unto a very smooth frame rail it might not ever get enough water or crud to do much damage. (maybe depending on where you live.) But I had to actually replace a couple parts of my top frame section, I could punch a screw driver right thru it. It may be that I wasn't the first person to put new floor pans in this car. And the last attempt left many gaps.
I also could be, with out a doubt that I am paranoid. I take GREAT pride in over building everything. :smile:
Hope you all have a Merry Christmas.
GregW
Platinum
Re: test
Hi Dave,
Tongue in cheek. That shot is the rear cross piece with some deep rust pocks. Unless the joints are really well sealed, water will wick into the crevices. Water spraying up from the tires kinda hoses that area down.
vette
vette
Re: test
Ah yes, I do recognize it. surprisingly I had no trouble there. But the trunk floor was bad forward of those oval opennings.
PAUL161 T-Series 55 TF Floorboard screws MG 4
Michael Oritt Boot floorboard? Austin Healey 9
T TR2/3/3A What are these holes for? -59 TR3 floorboard Triumph 1
J Bugeye exhaust question - am insulating floorboard Spridgets 2
71tr Floorboard Repair Options Triumph 16
T MGA MGA question - floorboard and firewall question MG 12
G My new Triumph floorboard removing tool.....plasma Triumph 5
R6MGS TR6 TR6 Floorboard "Donut" Triumph 5
H floorboard install question MG 22
G Fiberglassing a floorboard Triumph 10
tony barnhill Floorboard Rust Repair MG 14
Z removing floorboard goo Spridgets 9
blacksummerrain TR6 TR6 Floorboard Bolts Triumph 6
J TR 4 Norris Cam 342S Spec Sheet Racing 1
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
D Made a sheet metal break. Restoration & Tools 5
B Bugeye Original Engine Compartment Sheet Metal. Act Fast! Spridgets Classified 0
N Spridget sheet metal Spridgets Classified 0
J For Sale Triumph TR 2/3MISC sheet metal parts Triumph Classifieds 1
Busted knuckles TR2/3/3A Sheet metal question, Triumph 5
71TR6 TR2/3/3A Moving a radius on sheet metal patch Triumph 12
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
Tinkerman TR2/3/3A 1960 tr3a sheet metal fitment Triumph 6
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
T TR2/3/3A Repairing thin aluminum sheet metal like the grill. Triumph 6
Scot1966 TR6 TR6 sheet metal Triumph 3
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
doc50 Best Method to weld sheet metal repair panels in... Triumph 10
Triumph_TR4_Girl Log-Sheet For Renovation Project Triumph 9
D austin healey sheet metal Austin Healey 2
M sheet metal thickness Spridgets 3
M New sheet metal trades Spridgets 0
R 100-4 sheet metal Austin Healey 1
Tinkerman 1975 MOSS price sheet Triumph 9
Michael Oritt Sheet metal for cockpit Racing 4
W restoring a BN2 - need advice on sheet metal Austin Healey 10
P BUGEYE--sheet metal thickness? Spridgets 6
S Sheet metal Austin Healey 14
T Sheet metal brake - must or just nice to have? Triumph 13
P interior sheet metal removal/replacement Austin Healey 21
R BL US Competition Dept. sheet Austin Healey 2
Popeye Sheet metal question from a rookie Restoration & Tools 5
beaulieu drilling out sheet metal spot welds ? Restoration & Tools 11
A Moss vs Victoria British sheet metal parts Austin Healey 4
S Welding sheet metal Triumph 17
WALTER Sheet metal next to radiator Spridgets 1
svtmikey sheet metal question Restoration & Tools 6
T What sheet metal gauge are Triumphs made of Triumph 11
JPSmit Sheet Metal request Spridgets 5
eschneider homebuilt / economy sheet metal press brakes? Restoration & Tools 0
