Fibreglass body paint removal
Scimitarman
Hello
I am interested in your opinions on how to completely remove the paint on a 70's fibreglass bodied car.
The BEST way and not neccessarily the most commercially viable.
Also any useful links to DIY fibreglass body restos for a newbie would be appreciated.
Many Thanks
Darren James
Unfortunately, Darren, it's best to use a mechanical process. There are some chemical strippers out there (which don't turn 'glas to jelly!) but both the mess they make and time involved are a poor trade-off. 80-grit and elbow grease are the safest most efficient, IMO. Then patch any stress cracking, add a layer of the paper thin mat, contour with blocks and boards, epoxy prime, final block then finish... a long arduous process.
Bob Claffie
A number of years ago I stripped a vintage Corvette down to the glass. I used a combination of stripper, a DA sander and single edge razor blades about equally. Stripper is messy as mentioned above and now not politically correct. DA is relatively fast but you must be careful not to press too hard and make waves. Razor blade was very effective as the car had a heavy coat of enamel in addition to the original paint, primer, etc. Bob
WhatsThatNoise
DrEntropy said:
Then patch any stress cracking, add a layer of the paper thin mat... a long arduous process.
But when you're done it is as strong as the original and no bondo.
BTW...I like the woven cloth mats using the epoxy 'WEST SYSTEM' that boat builders use.
Some say that it creates a crack right next to the one you are repairing on account of the epoxy being many times stronger and inflexible.
Personally I like it because it isn't quite as toxic.
NEVER do any traditional repairs w/o a new 3M mask..
Your lungs will dissolve...I S&#t you not....
One hour in the garage unprotected and you will die!
*cough-cough*
4tecdog Fibreglass bonnet washer fittings Spridgets 5
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
Aggudabbu Stiffening fibreglass bonnet Spridgets 9
B TRIUMPH TR6 BODY SHELL Triumph Classifieds 0
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
A Recommendations for body repair near NYC Restoration & Tools 2
H GT6 Replacement body panels Triumph 4
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
R TR6 Body Parts Source, Upper Midwest Triumph 6
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
Popeye Transporting freshly painted body panels? Restoration & Tools 11
K TR2/3/3A What is the distance from the rear overider to the body....... Triumph 3
F TR2/3/3A Tr3A body body mount packing Triumph 2
S TR2/3/3A steering column through the body tub Triumph 5
BJ8Healeys BJ8 Body Parts Code Austin Healey 5
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
R Luggage Rack for 62 Sprite [Square Body] Austin Healey 1
Got_All_4 TR6 Body Jig Triumph 16
S TR2/3/3A Painting the body tub exposed parts again Triumph 19
D TR2/3/3A Frame/body centerline Triumph 10
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
H Bugeye Windshield to Body Gasket Spridgets 1
PeterK TR2/3/3A Ebay rolling Devin body moded chassis - with O/D Triumph 1
K TR2/3/3A Pressed steel body plates?????? Triumph 7
H Windshield to body seal Spridgets 9
J Attaching new BJ7 Dashboard To Body Austin Healey 7
Rut Bugeye windshield to body seal Spridgets 8
S TR2/3/3A tr3 front apron body work Triumph 9
G TR2/3/3A sealing body seams? Triumph 12
S TR2/3/3A body work on doors Triumph 5
