• Dear Guest!
    A paid subscription is not required to participate at BCF. However, if you find this forum to be a useful resource, and if you want to ensure we can stay online - Please consider supporting us by **Upgrading**
Faulty Indicator Repeaters
T
Tricky
When I bought my BJ8 7 years ago the dashboard indicator repeaters worked correctly intermittently. Now they both flash together everytime. I have checked and tightened all the connections and the end result was the flasher unit increased in speed of flashing. The flasher unit is a different Lucas model on these later cars. The early ones were a Type 4 and there is a diagram and complete description of how it works in the BMC workshop book but nothing about the later one apart from the Electrical Wiring Diagram showing a different layout on the later models. It appears to show the repeaters having a common earth through the middle, P, terminal on the flasher so I presume the connections and workings inside are different to the Type 4.
Does anyone know what the model number is of these later Lucas units which have spade terminals rather than screw. And any links to how they work and advice on fixing this issue would be appreciated to solve this longstanding issue.
Cheers,
Richard
Bob_Spidell
If both indicators--and, presumably, your turn signals--are flashing at a reasonable rate (appox. 1/s) then the problem isn't the flasher. The problem is most likely in the trafficator or its harness; possibly a couple wires have shorted together.
D BJ8 gas gauge faulty Austin Healey 32
B Faulty sparking plug Austin Healey 2
A Overdrive Help 3 & 4 Gear selector switch faulty? Austin Healey 10
KVH General TR Green Turn Signal Dash Indicator Triumph 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
Rob Glasgow Turn Indicator Austin Healey 17
S Indicator / Horn Switch Austin Healey 10
T TR2/3/3A turn indicator bulbs Triumph 26
D TR2/3/3A center panel indicator light color Triumph 10
B Turn Signal Indicator Light Always Flashing Austin Healey 10
T TR2/3/3A What causes fast flashing turn signals when all bulbs & indicator light are flashing? Triumph 15
B Indicator speeding up with time Austin Healey 4
A MGA High beam indicator light not working MG 2
R TR2/3/3A Steering Hub Turn Indicator lever Triumph 7
B The little silver indicator knob Austin Healey 0
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
N MGB "Indicator lamps" MG 0
6 Indicator Lamps Spridgets 3
sim Sprite 58 turn indicator problems Spridgets 10
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
P Coolant level indicator wrong? Jaguar 4
N Turn indicator switch??? Spridgets 1
S Turn Signal Indicator Spridgets 9
Y M Series indicator lens TVR 3
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
GTP1960 TR2/3/3A High beam indicator malfunction Triumph 3
DerekJ Indicator blinking too fast Austin Healey 13
T Horn and rear right indicator stopped working...head scratch imminent Austin Healey 16
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
Kleykamp TR2/3/3A 1961 TR3 turn indicator diagnosis? Triumph 4
T TR2/3/3A Flasher indicator dash light Triumph 3
L Bugeye dash indicator assembly pieces ? Spridgets 0
J Turn signal dash indicator lights Austin Healey 20
L Thread size, indicator head to stator tube screws Austin Healey 0
B Traffic indicator rotor woes Austin Healey 5
M Indicator Flaser Relay Austin Healey 13
B Indicator light modification with LED Austin Healey 14
I TR6 TR6 turn indicator Triumph 1
Scotsman Inoperative Direction Indicator Warning Light Triumph 5
Simmo TR2/3/3A TR3 Indicator modifications Triumph 1
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
Boink Bugeye turn indicator or signal... Spridgets 18
middie Which indicator lights to use? Spridgets 4
Anthony_S Turn signals and indicator light Triumph 11
S TR2/3/3A tr3 turn indicator Triumph 9
I Bugeye turn indicator light help please Spridgets 18
H Indicator of original color? Austin Healey 6
jjbunn Steering wheel and Indicator Stalk Jaguar 7
