Equivalent Brake Fluid
Got_All_4
I hate to bring up the brake fluid discussions again because I know what always happens but what prompted me to ask is I went into Team Triumph and purchased a rebuild kit today for my clutch master cylinder that went out on me last week. There was a new brake master cylinder on the counter from TRW and a big orange sticker that said if DOT 5 brake fluid was used it would void the warrantee. That started a discussion with the owner and me since I like to use DOT 5. I have it in my TR250's system. The clutch repair kit is also TRW made so I read the instructions in it and said to use what the manufacture recommenced. You can't find the Castrol Girling or GTX anymore and I know that's what I used in my TR3 when I rebuilt it back in the late 70's. However I don't know what I used a few years ago when I replaced the pistons in the front calipers.
Andrew Mace
Castrol GT/LMA seems to be routinely available at Pep Boys in the Albany, NY, area. If you have a Pep Boys, you might want to check them out. As for TRW not liking DOT 5? Well.... :devilgrin:
Unless the rubber seal formulation is vastly different under TRW than it was under Girling / Lucas, I can only note that hundreds of folks seem to have successfully used DOT 5 in their Triumphs with Girling / Lucas (/ TRW) systems. (Not me; I'm still a diehard GT/LMA fan m'self!)
TR3driver
Great Pumpkin - R.I.P
:iagree:
with the caveat that a very few people have had trouble with freshly resleeved master cylinders not liking DOT 5. Apparently sometimes, when the clearances are a bit on the tight side, the piston can bind and not return properly.
ISTR someone reporting that just working the cylinder a dozen times or so by hand made the problem disappear.
davidk
The same warning came on my freshly rebuilt and SS sleeved master cylinder from Apple Hydraulics. Been working fine with DOT 5 for a couple of years now.
DougF
I've had success with Dot 5 with TRF rebuild kits, but not certain of their source.
70herald
Most likely because air bubbles are common with Silicone brake fluid and instead of getting the air out, the new master cylinder gets returned as "defective"
hondo402000
I just purchased 2 quarts of Castrol last week and the bottle looked different and said synthetic on the bottle, I ask the guy at the counter, which by the way was an import parts house and I asked was it still compatable with foreign cars like triumphs and he said yes
we will find out
Hondo
DNK
Doesn't Apple have a warning about Dot 5 because of that?
swift6
we will find out
Hondo
That is because of the court case that Castrol won where they stated that anything made in a factory, processed, made by man etc... is Synthetic. The courts agreed so now Castrol puts Synthetic on just about everything. The Castrol GT-LMA with "synthetic" on the bottle is no different than the stuff without "synthetic" on the bottle. Synthetic does not = Silicone, especially after the aforementioned court case.
tdskip
TR3driver said:
:iagree:
A tad off topic, but this is a known issue with MGA/Bugeye MC seals. After about 50+/- time being worked all will be well but it is a bit eye opening when you first experience it. As Randall said you just need to keep working the seals.
GBRandy
DOT5 has been in my TR8 for the past 10 years. I rebuilt the clutch system and the DOT5 went in. A few years later I did the brakes with new seals, SS lines, etc and that also got DOT5.
Knowing that bubbles can cause an issue, my bleeding process was a bit more aggressive.
I have never had a problem and have only had to rebuild the clutch master cylinder once since I switched....and I drive the car a lot.
CinneaghTR
I was searching on this the other week and there was a lot of great information in the Healey forum on this. I've gotten LMA at my local Pep Boys, too.
I "liked" Castrol on Facebook hoping to get updates like "Castrol LMA is still the same!," "Hypoy GL4-Now at Pep Boys!," and "We like old cars," but all I get is updates for John Force's drag racing team. :madder:
StagByTriumph
I have been running Silicone DOT5 in my Stag now for 8 years, supplied by Classic Tube. Flushed twice in 8 years with new fluid on brake service just to keep it looking fresh.
Zip - nada problems, no leaks.
The problems people have had were with DOT5 that was 100% silicone and no lubricants added. NAPA and the stuff sold by Classic Tube both have non ethylene glycol lubricants to keep the seals sliding properly.
Someone told me that some DOT 5 fluids do have Ethylene Glycol that attack natural rubber, so read the label first.
MadMarx
no fast driver would use that stuff as it gives a soft spongy pedal feel.
and it doesn't withstand heat too well in racing.
I use DOT4 or DOT 5.1 at my race car.
BTW...hydroscopic brake fluid is not a failure....they want the fluid like that to maintain a good brake when moisture entered the system. DOT 5 doesn't provide that.
Cheers
Chris
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
S Redline MTL or equivalent? Austin Healey 28
steveg Canadian Equivalent to Harbor Freight Austin Healey 3
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
D TR6 Fuse equivalent Triumph 11
R 1275 midget equivalent replacement radiator Spridgets 13
R weber 32/36 dgv carb -- holley equivalent? Spridgets 2
T TR6 TR6 Tire Sizes - Modern Equivalent to 185 SR 15? Triumph 13
P TR6 TR6 Bulb Equivalent Triumph 6
Steve Finding the Holy Grail: The car nut's equivalent Jaguar 16
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
