Engine Question
tony barnhill
Great Pumpkin - R.I.P
Here's a photo of the engine Glenn Towry built for my MGB V8 conversion project...though I'm running a Boxer split intake cross-flow manifold with quad 44's, I've got the stock thermostat cover...I need to replace it with one that has more of an angle on the hose pickup end as the stock one points upwards too much. Anybody have a parts number cross reference or a suggestion about what will work?
Getting ready to put it in yet?
tony barnhill
tony barnhill
Yep, car comes back from paint booth in April
Cool!
tony barnhill
tony barnhill
But I still need to solve the thermostat housing problem - need one that points directly towards radiator, not upwards.
swift6
Tony, the photo is sort of fuzzy, maybe it's my eyes this morning..., but it looks to me like that housing is on backwards? Does it really point up? On my TR8 the housing points to between the alternator and the distributor (same locations as on yours). All of my current photos don't show the set up because the air pump hoses cover up the entire area. I'll see if I can get some better photos. Otherwise... Woody Cooper at The Wedge Shop (in Mass.) 508-880-5448, Brad Wilson at Wedgeparts (in Tenn.) 931-645-5283 or Ted Schumacher at TSI (in Ohio) 419-384-3022 could possibly help you out with a different thermostat housing. There could also be a Land Rover housing that could get you where you want to be.
tony barnhill
tony barnhill
[ QUOTE ]
[/ QUOTE ]
Yes, it is on backwards; & yes it really points up even when installed correctly
I had it on backwards for shipping & never turned it around....when turned around, instead of pointing directly at radiator, it points upwards at about 45-degree angle.
Thanks for theheads up on those contact points - forgot Ted Shumacher...
Andy Blackley
I have a fuzzy memory that some standard GM housings bolt right on. That might provide a lot of possibilities.
swift6
[ QUOTE ]
[/ QUOTE ]
That would make sense given the engines origins.
Let's see... The rover aluminum V-8 started out as a Buick 215 right? What buicks were these used in? You might find something at Advance that'll work.
swift6
It was a Buick, Olds, Pontiac engine. Though the only GM car that I remember hearing about it being used in was the Olds F85 Starfire (normally aspirated) and the Jetfire (turbocharged). A larger version, 300cid was also in production but I don't recall the cars that it was in either.
Back to Tony's dilemna. My TR8 housing looks the same as the one he already has. It just mounts differently (early carbed version). If Tony's housings gasket surface is horizontal, my TR8's is vertical where it mounts to the intake manifold.
Tony, will a lesser angled housing still allow the hose to clear that fan, or is that fan coming off in order to switch to an electric fan?
tony barnhill
tony barnhill
No, I'm keeping the fan &, though I'm in a hotel aweay from home right now, I think a lesser angle will clear it.
tony barnhill
tony barnhill
No, Shawn, I'm in Kansas City this week....will be in Hawaii from 29 May until 3 July...
swift6
Oh! Then you must wish you were in Hawaii. /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/devilgrin.gif
tony barnhill
tony barnhill
Yep - do wish it...but 6 weeks over there in summer will cure that wish!
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
L TR2/3/3A Stupid Engine cleaning question Triumph 9
H MGB Engine build question MG 10
M 948 Engine Rebuild Question Spridgets 0
L TR2/3/3A Engine plate question Triumph 5
JPSmit Kind of an engine question Spridgets 11
T Sunbeam/Hillman engine question Sunbeam (Rootes) 6
KVH TR4/4A Engine Question: The Valve Lifters Triumph 9
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
M MGB Help with engine code question. MG 5
JPSmit Question two - leaning out the engine Spridgets 6
NutmegCT Flat head [L-head] engine question Other Cars 5
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
T TR4/4A Question on engine block Triumph 8
2billydavies TR2/3/3A question about where to bolt into when lifting/replacing engine Triumph 11
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
JPSmit engine oil cooler question Spridgets 11
TulsaFred Engine Install motor mount question Spridgets 5
F TR6 Starter Relay = Low Engine Power Question Triumph 13
A 100 engine main bearing cap nut question Austin Healey 0
JPSmit Engine Rebuild question Restoration & Tools 10
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R low/high temp engine running question Spridgets 23
7 General Tech Engine vacuum, tuning question Triumph 7
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
J 1800 engine question MG 14
S engine is back, tub is bare,frame is bare Question Triumph 9
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
B TVR with Essex V-6 engine question TVR 5
B Curious question..Engine Coolant container MG 10
JPSmit Engine Question Restoration & Tools 5
H engine paint question Austin Healey 19
B Wedge Tr8 engine removal question. Triumph 13
JPSmit Viva GT question [seized engine] Other British Cars 5
NutmegCT TR2/3/3A TR3 engine question Triumph 6
S Spitfire Question on VIN and engine number for spitfire Triumph 5
S old question maybe?, rebuilt engine Triumph 3
BN6_2197 Question on Engine Compression Austin Healey 9
A question about media blasting and engine paint. Austin Healey 14
J Engine Question Austin Healey 7
MGTF1250Dave TR4/4A TR 2-4A Engine Dissassembly Question Triumph 5
14dna Nissan Engine Question Spridgets 5
H Engine rebuild question Triumph 6
J Engine Swap question Spridgets 25
UmmYeahOk Chassis/Engine # Question Triumph 12
T Engine pulling question - where connect Triumph 10
P General engine question Triumph 5
