Engine number plate
Lin
What is the best way to remove the engine number plate(29D-BT7)? Just drill out the rivets seems the obvious answer, but I thought I would check with the authorities. Thanks
Lin
1960 BT7 in restoration
1959 Bugeye
MotorHead67
I'm glad you asked that question.
I removed mine, prior to the engine rebuild, by carefully grinding the rivet heads off with a dremel. Now I've got to figure out how to get it back on. I thought I would move it over enough to clear the old rivets and drill in new ones (if I can find similar rivets).
64 BJ8
Hi! I used a Dremel tool also, but used it to grind a small slot across the rivet head & then used a screwdriver to screw it out. New rivets are available (ex: Moss).
John Loftus
Lin,
The best way is to take a thin blade, like an artists putty knife with thin gage metal and pry the rivet out. It shouldn't take much to pry it out unless it's rusted in (mine pryed out easily). You can even reuse the rivet this way and you know it will fit! If you do need new rivets they are avail. through www.britishcarspecialists.com
Cheers,
John
Lin
Lin
Thanks to all. I cut a slot with my dremel tool and then turned them out with screwdriver. Put a little liquid wrench on the night before.
Lin
R Engine Number Plate Austin Healey 2
L First 100 Engine Serial Number Plate Austin Healey 13
Rut TR4/4A Engine number and body plate Triumph 5
L replacement engine number plate? MG 6
C Spitfire Red painted engine number Triumph 3
Pool Dad 1960 TR3 engine serial number Triumph 14
S TR6 Chasis number, engine number register Triumph 2
F TR2/3/3A Commission and Engine Number Triumph 7
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
V TR2/3/3A Unusual Engine Number Triumph 5
C TR4/4A TR4 Engine Number doesn't seem to make sense Triumph 6
Geo Hahn MGA Engine Number on an MGA MG 3
H engine number eaten Austin Healey 16
Randy Forbes Longbridge Engine Number / Clarke Spares Owner Passed Away Austin Healey 5
S Spitfire Question on VIN and engine number for spitfire Triumph 5
CJD Engine Number EN17842HE Triumph 2
blueA Engine number Other British Cars 8
H Engine number "1"CH or "I"CH for the LongbridgeBN4 Austin Healey 1
dklawson Spitfire Ping Andy Mace - Spitfire Engine Number? Triumph 5
hilsideser engine block number Triumph 8
R mg midget engine ID number info, what year engine? Spridgets 12
R TR6 TR6 engine number Triumph 6
Atrus Car [Vin/Engine/Body] Number help... Spridgets 14
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
M TR6 TR6 Engine number Triumph 2
R midget engine id number what built in which year? Spridgets 11
Monark192 DMV has engine number as VIN MG 8
W blank engine number MG 1
jjbunn Engine number 8 G-U-H 25079 MG 13
timbn2 engine ID number confusion Austin Healey 1
AUSMHLY Correct engine number help Austin Healey 11
M Decoding VIN and/or Engine ID Number & What Oil MG 6
C Engine number MG 7
davidk Need help with Engine Number Triumph 4
Michael Oritt Elva Courier engine number--assistance MG 9
D Engine Serial number MG 9
R TR6 Confused over TR6 Engine Number Triumph 5
1 engine serial number Spridgets 13
johnrip Wedge TR7 Engine Serial Number Triumph 2
B de-coding a VIN and engine number British Motor Corp 1
N FE engine number??? Triumph 3
tlthorne big Healey engine number question? Austin Healey 4
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
