Engine Mounts
Morris56
Easy question for the day... are the engine mounts painted black or the engine color. 5 interlocking pieces for an engine mount... no wonder these cars cost so much to re-build.
Thanks for the help
AH100M
Engine color. Including the rubber blocks. The mounts installed on the engine and the whole thing was painted green before being installed in the car.
Cutlass
Complicated? Take your trafficator apart to find complicated. Or how about just the door check straps, or the carb linkage? This car amazes me. The complicated engineering is very interesting to observe.
And I just cleaned and painted my engine mounts last week. I painted all the metal parts engine green but painted the rubber parts black. Their in so I'm not pulling them back out.
This is the first(and probably the last) BJ8 I've ever done from the ground up. Its been a challenge. I didn't spend near this much time (or money)on the XKE. Going back to TR's after this.
Marv
One of each
W BN4 Engine Mounts Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
D TR2/3/3A Engine mounts Triumph 11
71TR6 TR2/3/3A New engine mounts not sitting flat Triumph 41
Bob_Spidell Engine Mounts Austin Healey 19
KVH TR4/4A Dropping the Engine and Transmission Back onto the Mounts Triumph 22
S TR2/3/3A Engine mounts Triumph 8
C 3000 engine rubber mounts Austin Healey 1
F TR2/3/3A Engine Mounts TR3A Triumph 2
oxford Engine mounts Austin Healey 0
Boggsy64 MGB Transmission engine mounts and front engine mounts MG 0
H TR4/4A TR4A engine mounts Triumph 4
M Engine Mounts Spridgets 1
coj Motor Mounts AH 3000-1960 with 29 F engine Austin Healey 6
coj Engine mounts 1960 AH 3000 with 29 f ENGINE Austin Healey 1
W Replacement frame engine mounts for a 100-6 Austin Healey 4
S MGB MGB engine mounts - "extra" plate? MG 2
T TR4/4A TR4a engine mounts - round vs rectangular & vendor Triumph 13
drooartz Do I use: trans brace, braced engine mounts Spridgets 2
CinneaghTR TR4/4A TR4 v. TR4A engine mounts? Triumph 4
KVH Engine Mounts Triumph 4
S Spitfire Rear engine mounts - Spitfire Triumph 2
Bruce_B Source for Motor Mounts for 1275 engine? Spridgets 4
JPSmit Tonight's Questions - engine mounts Spridgets 4
Guinn engine mounts MG 2
Hegg Elan +2 - Engine Mounts and Clutch Adjustment Lotus 6
Dave Russell Big Healey Engine Mounts Austin Healey 10
W Loose engine mounts MG 3
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
