Engine I.D. tag
Sparky
Member
I am trying to identify the engine in my 74 gt. For some reason the tag is missing.Is there another way to identify?
Thank you
Paul
Frazier
By serial number. Moss catalog has a Production Data page near the front. For Model Year 1974 starting with car (GT) 328801 it indicates an 18V engine. I'm sure the Bentley manual can be helpful as well but I don't have it handy.
Frazier
David Brotchie
How else can you ID an egine block if the tag is missing? I only have the word of the previous owner who said the previous owner said that the block is a 1969.
The subject block is from this thread. It is a 5 main block and cast on the side is 2H3 508.
John Moore
If the tag isn't pulled before the block it hot tanked before a rebuild, it will be eaten away. That being said, the next best way to figure out the build date of your engine is to look for the 'clock' stamped on the side of the block. I apologise to Basil for linking you to another forum, but its discussed in this thread how to read 'the clock'
https://www.mgbexperience.com/phorum/read.php?f=1&i=49479&t=49479#reply_49479
Nelson Replacing engine ID tag Spridgets 15
bighealeysource Engine ID tag color on BN2 Austin Healey 3
vping Engine ID Tag Spridgets 12
PeterK TR4/4A TR4A engine block tag Triumph 2
fmichaels engine vin tag Spridgets 5
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 38
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
